hellocontrol for collet chucks ( please check attached ):
... craft the green piece, basically a solid collet + arbor
... mark the chuck, then insert it in the chuck , then manual rotate it : is needed to see contact loss towards the botoom, towards the small diameters, thus to make sure that main contact occurs near chuck face
... check that orange distance, to be minimal, not only for this green part, but also when mounting collets; if it is too small, then recut the chuck face
... clamp the green piece, and check tir near and far, if it is not ok, then chuck cone has to be refreshed
long term use of -1 range collets and solid nut, leads to wear, because of
... twist :
...... more pronounced wear : between collet small taper and nut
...... less pronounced wear : between collet long taper and chuck, especially towards the chuck face, because original product is designed to make contact towards the face; if this area gets wear, then tir will appear
... drag : like besides twist, the collet had a tendency to scracth the ( slide in ) chuck inside cone, longitudanlly
when h7 range collets, and bearing nuts are used :
... twist does not occur
... drag occurs, but is minimized
* wear manifests later, for both chuck & collet
for same force aplied, a collet with more grooves will deformate more than a collet with less groves, so they will stick diferently to the chuck, thus when reversing the nut, to unmount them, the collet with more groves will be easier to pull out; as a side note, the collet with bigger range, has to be softer than a collet for h7 range, otherwise it will break into pieces; as a consequence, the collets with less groves and less range ( thus precision collets ) make stronger contact with the chuck, so if they are tighetened with a normal nut, then, they won't rotate inside the chuck as much as a many grooves collet does, and this means that during the last few turns of the nut ( or the last 1/2 turn ), the collet being static, wear will appear in the contact area with the nut
thus is better to use a static nut on a high range collet, instead of a precision collet, or you'll scracth those precision collets too fast, but those may still work, as long as the nut won't be able to tilt them inside the chuck cone; a precision collet is harder to tilt, while a big range collet is easier, being less resistive
as for threads, precision assemblies, are designed to rotate and fix after a predefined number of turns, preferably minimal; if the number of turns is bigger, then the nut will have the tendency to still rotate for a bit too long, after the collet has allready being fixed in the position; this means that, if someone is stronger, he will torque that nut for too much, while, with a precision assembly, he won't be able to torque it any futher, because it allready blocked mechanically
this type of precision is not comonly found in er systems, but more in gang systems, for collet chuck spindles, that fix/blocks after a small amount of turns; but is one reason why some quality collet vendors recomand their chucks and nuts, so to achieve minimal tirr,
as a conclusion, in the end, you may trust the vendor/dealer as he sais that he has quality, or better have in house control/methods; i mean reliable methods, proven, because, for example, simply a dial inside the chuck does not mean that the chuck runs true; you have to tram it somehow; best quality methods do not evolve from final inspection of random products, but from knowing how to craft them tight, in repetitive manner / kindly![]()
