587,481 active members*
3,279 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Doosan APC will not clamp
Results 1 to 2 of 2
    Jan 2015
    3
    New to us Doosan VC 430 has a new issue. APC table will not clamp. Table is not descending low enough to touch microswitches that confirm clamp position. Switches are working. Service tech visit is at least a week out. Any assistance would be appreciated.
    Jan 2013
    474
    Quote Originally Posted by stevemay55 View Post
    Is this a twin swivel type pallet changer? If it is, check the pallet lift carrier switches, also the lifting wedge on the pallet is properly engaged. Could be jammed with chips (swarf). Check the lower carrier end stop adjustment, bolt may be loose.
    But first, use manual functions to swivel half way and clean under the pallets with a wash gun.
  1. DS0300 APC Alarm on DOOSAN PUMA 2600LSY
    By DanielBamek in forum Fanuc
    Last Post: 03-29-2022, 07:08 AM
  2. Doosan Puma TT1800SY - APC "Alarm" on start up
    By Saranac in forum Daewoo/Doosan
    Last Post: 06-28-2015, 03:07 AM
  3. APC Alarm - Doosan Puma TL2000
    By bullet01 in forum Turning Machines
    Last Post: 12-15-2011, 03:05 PM
  4. doosan ACE-H100 pallet APC arm return fault
    By suresh patil in forum Daewoo/Doosan
    Last Post: 10-01-2007, 04:30 AM
