588,107 active members*
5,903 visitors online*
Results 1 to 8 of 8
    45 degree problem
    Hi friends,
    I have a big problem, the quality of the surface finish at 45 degrees is extremely bad, the resolvers and tachos are new , but apparently the axis numbers become similar with a delay and lag.
    What could be the problem?
    Aug 2009
    1573
    Re: 45 degree problem
    ...SETP to Axis Lag ....then, check the Balance of X and Y ..Program O5811- O5815
    https://nxgenparts.com/content/Maint...e_Programs.pdf
    hi
    all axis balance between 0-1
    Which parameter is there for axis lag in setp?
    Aug 2009
    1573
    Quote Originally Posted by Mhook View Post
    hi
    ...go into SETP at Comman Line...hit the Space Bar twice and on page3 go to AXIS DISPLAY and set to ERR.
    then run this Service Program
    O5811-Balance should be Inch:BALLSCREW 595, Metric BALLSCREW 700ipm: 302
    N1 O5811 (BALANCE INCH:BALLSCREW 595, METRIC BALLSCREW 700IPM: 302
    N2L100
    N3M49
    N4X5.Y5.Z-5.G1F150.
    N5X-5.Y-5.Z5.G1F150.
    N6M17
    N7M30
    N8M91G91(START OF THE MAIN PROGRAM
    N9(
    N10(*FOR INCH BALLSCREWS:
    N11(BALANCE ALL 3 AXES TO 595 ON THE DISPLAY OR 1.44 VDC
    N12(AT THE COM AND SIG2 LUGS OF THE AXIS AMPLIFIER
    N13(*FOR METRIC BALLSCREWS:
    N14(BALANCE ALL 3 AXES TO 302 ON THE DISPLAY OR .735 VDC
    N15(AT THE COM AND SIG2 LUGS OF THE AXIS AMPLIFIER
    N16(
    N17(
    N18L101.1
    N2L100
    N3M49
    N4X5.Y5.Z-5.G1F150.
    N6M17
    N7M30
    N9(
    N16(
    N17(
    N18L101.1
    thx a lot
    N2L100
    N3M49
    N4X5.Y5.Z-5.G1F150.
    N6M17
    N7M30
    N9(
    N16(
    N17(
    N18L101.1
    It makes no difference!
    In addition, Fadal's eprom program is wrong. The correct number for the metric ballscrew is 595 ! not 302
    Jun 2011
    32
    Axis thrust bearings are a common wear item on Fadals. The first evidence is usually quadrant lines during circular interpolation. It can also express as less than great finishes during angular moves.
    My $0.02 (US)
    Aug 2009
    1573
    ...have you checked power supply Voltages and the AC Ripple...follow Chapter 11 Troubleshooting for more things to check.
    https://itscnc.com/pub/media/documen...leshooting.pdf
  1. Replies: 2
    Last Post: 11-07-2022, 04:28 AM
  2. Replies: 0
    Last Post: 07-23-2016, 12:14 AM
  3. Replies: 9
    Last Post: 06-05-2014, 04:41 AM
  4. Replies: 3
    Last Post: 06-30-2008, 01:30 AM
  5. 0.9 degree stepper. Use or not?
    By jdholbrook in forum Stepper Motors / Drives
    Last Post: 05-28-2006, 06:47 AM
