587,719 active members*
3,620 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma rs232 file format
Page 2 of 2 12
Results 21 to 34 of 34
  1. #21
    Apr 2006
    825
    Re: Okuma rs232 file format
    See if this file helps you.
    Cheers
    Brian.
  2. #22
    Jun 2023
    9
    Hi all,
    thanks for taking out time for valuable time out of your schedule, I tried all ways but had no luck, finally, I shifted to a floppy emulator and just got it for 100 $ and communication is also faster,
    Now facing BUFFER OVERFLOW for bigger programs than 60 kb, can anyone please share a program format for how to call a multiple subprogram from main program?
  3. #23
    Aug 2011
    423
    Quote Originally Posted by sunilb View Post
    Hi
    I can upgrade your buffer memory limit. I think your control unit is U100M.
    If interesting please send PM
    "Imagination is more important than knowledge."
  4. #24
    Mar 2009
    1982
    it is called "shedule program". The program which calls part programs ( loacated on separate files ).
  5. #25
    Jun 2015
    4160
    hy sunilb, as allready mentioned in a previous post by kurmay, this can be fixed, so to enlarge available program size
    it's a way better alternative than schedule programs *.sdf
    please feel free to ask any question / kindly
  6. #26
    Jun 2023
    9
    Hi
    The controller on the machine is U10M,
    can you still help.
  7. #27
    Jun 2023
    9
    Gratitude Kitten,
    I am new to CNC machines, just learning by experience/youtube/forums ??, the machine is working well at this moment with small programs running turn by turn, I will try *sdf in the week to come.
    Thanks & Regards to all for such friendly behavior.
    - - - Updated - - -
  8. #28
    Jun 2015
    4160
    Hy sunilb, if you wish for buffer size increase, please share an e-mail / kindly
  9. #29
    Jun 2023
    9
    Hy Kitten, you can mail me at [email protected]
    please notify me after its sent, some times it goes to spam folder
  10. #30
    Jun 2015
    4160
    please contact [email protected]
  11. #31
    Jun 2023
    9
    sent it
  12. #32
    Feb 2010
    84
    Quote Originally Posted by deadlykitten View Post
    Can you tell me if the 1998 LB25ii on the way to me will use the same RS232 settings as the MC4VA I currently run? The MC4VA and Fanuc 10T use the same settings in the dnc software now. I'm worried there are a LOT of things I'm going to have to figure out with this new machine. Never ran OSP lathe before. Which canned, tapered threading cycle is a big worry. Loren
  13. #33
    Mar 2009
    1982
    In my opinion following "the good configuration" from other machine is wrong approach. You need a good cable and matching settings on both sides.
    If the setup is working for Fanuc DNC it doesn't mean that it is suitable for OSP file transfer.
  14. #34
    Feb 2010
    84
    Quote Originally Posted by Algirdas View Post
    The cable is good, and has been working for years on Okuma MC4VA with OSP5000G control, and Wasino LJ63M with Fanuc 10T control.
Page 2 of 2 12
  1. okuma osp format on PC
    By bvpr in forum Okuma
    Last Post: 05-22-2014, 10:54 AM
  2. File Format
    By jrmach in forum BobCad-Cam
    Last Post: 04-10-2014, 07:26 AM
  3. What is the name of this file format?
    By owenransen in forum Uncategorised CAD Discussion
    Last Post: 02-28-2013, 05:39 PM
  4. WinNc 3.1 File Format
    By whiteredline in forum Uncategorised MetalWorking Machines
    Last Post: 02-13-2012, 05:02 PM
  5. OSP 7000 LU-45 file format??
    By TriumphMachine in forum Okuma
    Last Post: 09-03-2010, 10:18 PM
