Originally Posted by
Dan Fritz
TheePress: The parameters in the 9100 area should be visible on all Fanuc 10, 11, 12, and 15 controls. They are not hidden. Be sure to press the SYSTEM soft-key (not the SETTINGS soft-key). Under SYSTEM, you should be able to see all the parameters. Under SETTINGS, you will only be able to see certain selected parameters that don't need to be un-locked with the PWE bit.
You should be able to see these parameters in binary, but you can not enter the option paramters like the other parameters. You must use the special procedure that has been described before on this forum. Just to recap, it goes like this:
power off, press "-" and "." at the same time, turn the power on, enter "99" then INPUT at the ILD menu, enter the number of axes, then enter each parameter in the 9100 range in hexadecimal
Good luck.
Dan
