Hi Dam - To calculate the max tension in the belt we need to know the acceleration of the weight. Does this occur over 50mm? 20mm? This acceleration will determine the forces not the speed. Then the least accel would be over 200mm so it speeds up to halfway then slows down to the end. It reverses and repeats. The average speed would be half the max speed. Will this run 24hrs a day?
2 secs cycle = 1,000,000x2=2M sec 2M/60/60= 556hrs = 23days so a 20sec cycle would be 230days ? what sort of cycle time are you aiming at???? What does it do? Does it make milk shakes?
Peter
If I were making such a rig I'd use a crank not a belt and pulley.... much easier. Whats the pitch of the screw? Vibration is in the lead screw not in the belt. Long screws vibrate but a short screw like this probably would not vibrate. Whats the diameter of the screw? Also need to know the inertia of the motor, do you have the motor spec? The motr needs to accelrate itself, the screw and the mass. Often the motor and screw are the highest inertial loads in such a system....
