603,316 active members*
2,788 visitors online*
Results 1 to 7 of 7
    Re: UC100 and Spindle speed off
    We need more information. What breakout board are you feeding the UC100 into? And, what PWM base frequency for the spindle speed signal does the breakout board require?
    Cheers
    Peter
    Homann Designs - http://www.homanndesigns.com/store
    Mar 2012
    239
    Quote Originally Posted by phomann View Post
    Cheers
    Peter
    I'm pretty sure that's irrelevant, it works with the PC parallel port setup, it doesn't the USB UC100 port... There must be something more to the UC100 setup, or it's not actually running 100Khz.
    I did get the win7 PC running again and verified with the parallel port, the spindle speed is good, so it's not a hardware issue.
    Mar 2012
    239
    Peter, it's also not using PWM, it's setup like another stepper.
    Mach3 Motor Tune
    Steps 2000, Velocity 2500, Acceleration 25
  1. Replies: 7
    Last Post: 07-15-2021, 05:24 AM
  2. high speed and low speed dual spindle CNC mill
    By GusBiz in forum Mechanical Calculations/Engineering Design
    Last Post: 02-13-2021, 08:54 AM
  3. Can UC100 Run At 400Khz So 6040 Spindle Runs 24,000 RPM
    By eddiegnz1 in forum Machines running Mach Software
    Last Post: 06-13-2019, 03:20 AM
  4. Replies: 1
    Last Post: 08-02-2013, 10:07 PM
  5. BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial?
    By peter.blais in forum Bridgeport / Hardinge Mills
    Last Post: 08-08-2006, 09:29 AM
