if you are using coolant you need a much bigger table top. You need sides to surround the whole machine otherwise coolant will go EVERYWHERE. I had flood coolant on my first
mini-mill but it was not particularly well thought out.........and I seemed to spend a lot of time cleaning up coolant leaks.
My new mill is vastly better, but still not as good as it should be. Hopefully sometime over the next twelve months I'll get to re-do the coolant system. I want a 100l tank, a pull-out tray filter and be able to remove the tank easily
to clean it out completely. I promise you'll have to do it every once in a while....and making it easy to do is a priority. I did my coolant tank over the weekend (annual event), took several hours, where with good design I should
be able to do it in under and hour.
Craig
