603,365 active members*
2,664 visitors online*
Results 1 to 12 of 12
    Re: AXYZ 4008 3 phase to single phase wiring
    Hello, I have an AXYZ 4008 that I want to run on a single phase. Curious to hear more about your process.
    Was it as easy as hooking up to the 2 breakers shown in the picture where it shows '220v-1ph' ?
    What was the setting you changed on the AC converter? This was causing the torque limit?
    Dec 2013
    21
    Quote Originally Posted by ml_macdonald View Post
    Yes, I just rewired the input to the 2 breakers under the '220v-1ph' label.
    I was able to find the setup guide for the inverter confirm it could be run on single phase, I did not need to change any connections anywhere else.
    The torque limit error was actually not an error, the status light is always red when the spindle is not spinning with or without an error. If the light turns red while a program is running, then it would indicate torque limit.
    The setting I had to change within the AC Converter was section 21 in programing, you can define input type. The setting had been switched to use inputs on the inverter itself, once I changed it to use the input control wires from the controller it worked as expected.
  1. Replies: 29
    Last Post: 02-12-2022, 09:20 PM
  2. Robodrill 7.5hp spindle. Single Phase Power input No Rotary Phase convetor doable?
    By whiteriver in forum CNC Machine Related Electronics
    Last Post: 01-05-2017, 09:01 PM
  3. Replies: 2
    Last Post: 09-24-2015, 07:04 PM
  4. how to connect single phase spindle motor with 3 phase inverter
    By pdsherathia in forum Benchtop Machines
    Last Post: 01-19-2014, 07:15 PM
  5. Replies: 12
    Last Post: 10-13-2009, 03:53 AM
