588,058 active members*
5,516 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Milltronics Partner VM-30 drawbar issue
Results 1 to 3 of 3
    Jun 2024
    I'm having an issue with the drawbar on my machine and am trying to find out how to remove it from the spindle. I believe some f the bellville washers are broken because the drawbar is too far down for the pancake cylinder to make contact with it. If anyone out there can give me some pointers on how to remove it, it would be greatly appreciated. The manuals I have don't have anything on how to remove it.
    Sep 2010
    531
    Re: Milltronics Partner VM-30 drawbar issue
    I have this info:
    I found another document, not sure if I can attach a pdf, will try.... had to do a link to my drop box
    https://www.dropbox.com/scl/fi/x138a...=159e46n6&dl=0
    Jun 2024
    Thanks Brian, this is exactly what I needed.
    Sep 2010
    531
    You can get the Bellevilles from:
    https://www.mwcomponents.com/belleville-washers
    You will have to do some research with a cross reference to find the right number... but they are a lot cheaper than ordering from Milltronics.
  1. Milltronics Partner I
    By cydrollinger in forum Milltronics
    Last Post: 09-10-2021, 10:08 PM
  2. Replies: 3
    Last Post: 08-06-2018, 01:00 PM
  3. Milltronics Partner VI, Partner 6 - $1.00 no reserve
    By donl517 in forum For Sale Only
    Last Post: 03-17-2018, 02:40 PM
  4. Milltronics Partner Power Drawbar questions.
    By sbalder in forum Milltronics
    Last Post: 06-05-2012, 08:55 PM
  5. milltronics partner II
    By jmanriss in forum Milltronics
    Last Post: 01-30-2011, 05:44 AM
