603,316 active members*
3,020 visitors online*
Results 1 to 2 of 2
    Oct 2017
    5
    X Axis moves manually but not with GCode
    Hello everyone!
    I'm using router Mack3 compatible. Everything was working normally but when I started the next operation the x axis is not moving anymore. I can home, no problem. I can manually move all axes. Everything seems normal but when the programs runs it hangs on the x axis and stays in place. The weird thing is that I can see on the controller's display all the movement on the x, y and z axes.
    %G90
    G0Z30.
    X285.Y252.5A0
    S1500M3
    G0Z30.
    X285.Y252.5A0
    G0X256.644Y445.355Z30.
    Z5.
    G1Z4.7F500
    X285.Z-.3 > This last line hangs forever but display shows movements.
    Any idea?
    Thanks in advance!
    Nov 2024
    15
    Quote Originally Posted by aefa View Post
    Hello everyone!
    %G90
    G0Z30.
    X285.Y252.5A0
    S1500M3
    G0Z30.
    X285.Y252.5A0
    Z5.
    G1Z4.7F500
    Any idea?
    Thanks in advance!
    Change your G code format
    If you can share your contact or email I can share the file for testing
  1. Problem with gcode on charmilles robofil - errant moves not in g code
    By MStockbridge in forum EDM Discussion General Topics
    Last Post: 11-25-2018, 10:05 AM
  2. Axis moves beyond the gcode-specified position
    By tanihera in forum Mach Mill
    Last Post: 09-19-2013, 10:24 PM
  3. Using Gedit without EMC2 to manually edit Gcode with syntax
    By mouratoglou in forum LinuxCNC (formerly EMC2)
    Last Post: 07-25-2009, 08:36 AM
  4. Is there a way to feed an offset in manually in Gcode
    By seanreit in forum Uncategorised MetalWorking Machines
    Last Post: 12-14-2008, 04:30 AM
