603,794 active members*
4,707 visitors online*
Results 1 to 5 of 5
    Mar 2008
    175
    Memory backup battery
    Any one know where to get a memory backup battery for a Fagor 8025T. Is there a local purchase substitute such as from interstate batteries that anyone has used?
    Dec 2010
    8025 battery replacement--it is not hard.
    The memory backup battery is just a 3.5v Lithium battery. However it is soldered into a box that has 2 resistors in it as well, hooked to the positive and negative ends of the battery circuit--I presume these are a mechanism to tell the charge left in the battery.
    Get a 3.6 v Lithium battery from wherever (Radio shack has them, as does ebay, etc.)
    Leave your control on so you don't lose parameters when changing the battery.
    Remove the battery case by two screws, then you will see a circuit board with 1 battery and 2 resisters on it .
    Use a utility knife or something with a similar wedge blade to get the spot welded ends off the factory battery without breaking them so you can solder the new battery back in place.
    Position the knife, whack with mallet and they come off easy.
    Solder new battery in place, observe polarity that is silk screened on the circuit board. Hint: solder won't stick to the plating on the ends of the battery, so use emery to remove the plating before soldering to the flat connectors.
    As a check, use voltmeter on new battery to see you have full voltage, so you know your solder joints are good.
    Reassemble black case so you don't short out anything.
    Re-install battery.
    Good for another couple of years. I've changed it 3 times in 14 years.
    Oh, as insurance, take a half hour and back up your parameters by using a digital camera to take a picture of each screen of the parameters. There are so few parms that it doesn't take long, and it is indisputable proof of what the parms were on a given date. I find it better than downloading to a file because they don't get lost as individual downloaded files tend to, and you can see any individual parameter without going though a list. But that may just be me. But backup before you change the battery, so if a power failure happens while you are soldering, you are not posting here about how to recover the parameters.
    Re: 8025 battery replacement--it is not hard.
    Hello,
    I'm going to get an old lathe with a Fagor 800TG-I control soon. I hear this control is very similar to the 8025. Can you tell me how to display machine constants on the screen so I can take pictures?
    Regards Darek
    Mar 2004
    185
    Re: Memory backup battery
    I wish I had read this before now .....
    Arrrrrhhhhh
    Ok, the battery went flat and I've lost all the parameters ......anyone can offer some help or where I should start
    It's a fagor 8055tc on a Kingrich Lathe
    Thanks.....
    Sep 2008
    54
    Just wondering if you ever got this straight. I'm in the same boat.
  1. VMC100/TM02 memory backup battery?
    By Viilari in forum EMCO Mills
    Last Post: 09-22-2020, 06:35 AM
  2. battery backup
    By Daniel Boone in forum Fadal
    Last Post: 10-03-2012, 06:17 AM
  3. Backup Battery
    By tear_inc in forum Milltronics
    Last Post: 07-17-2012, 07:49 PM
  4. Easy Q, what, where to get battery backup?
    By Brian FRF in forum Milltronics
    Last Post: 06-26-2012, 04:11 AM
  5. Acramatic backup memory battery charging problem
    By cnc1000 in forum Cincinnati CNC
    Last Post: 03-17-2010, 07:00 PM
