603,365 active members*
4,345 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Milltronics VM20 Z axis servo fault
Results 1 to 3 of 3
    Aug 2009
    24
    My VM20 is giving me a Z axis servo fault. On initial start up it may go into it after a few minutes. When I try and reset it it triggers as soon as I release the enable button. I’ve also noticed that the X and Y servos will continue to display the 66 numbers but the Z servo shows nothing but a blank led screen and a glowing red Charge indicator light. Any help would be greatly appreciated. Thanks
    Jerry Mills
    Michael’s Machine Shop
    Re: Milltronics VM20 Z axis servo fault
    Quote Originally Posted by bobo17 View Post
    Jerry Mills
    66 numbers on X and Y axis means ready.
    The Z axis driver might broken, need to replace with a new one.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Aug 2009
    24
    Quote Originally Posted by cncmakers001 View Post
    Thank you for the reply
  1. Need Help VMX24 servo fault at both axis
    By els_engineering in forum HURCO
    Last Post: 01-22-2021, 02:59 PM
  2. milltronics vm20 8200 control
    By Magpie26869 in forum Milltronics
    Last Post: 01-27-2016, 01:07 AM
  3. BMC 20 - Servo Amp Fault On Z Axis
    By gcude in forum HURCO
    Last Post: 01-13-2014, 08:28 AM
  4. VCE-750 with BLDC Servo - X Axis Servo fault
    By kostner in forum Haas Mills
    Last Post: 10-23-2011, 08:09 PM
  5. SERVO DRIVE FAULT ON AXIS S BMC 40
    By tallenttoolroom in forum HURCO
    Last Post: 08-30-2011, 09:59 PM
