603,344 active members*
3,716 visitors online*
Page 6 of 22 4567816
Results 101 to 120 of 438
  1. #101
    Feb 2007
    31
    alex751
    Quote Originally Posted by mcan View Post
    Tried to copy UHU's part but failed Changed the layout according to your point and ELM-CHAN's circuit.
    Hello!
    So did you made finaly controller?? Does it work???
    I would like to ask you on your previouse schematic you placed here there is R2 and R3 can you tell me nominals I mean how big is resistanse? Also do you have PWM on leg 15 and 16????
    Regards
    Alex.
  2. #102
    Jan 2006
    481
    Quote Originally Posted by smartgsm View Post
    i found in google this page:
    http://elm-chan.org/works/smc/report_e.html
    In my first view is very interesting.
    Specially on page is all: shecmatic and SOURCE code.
    Does anybody try this project?
    Br :cheers:
    Greg
    Hi smartgsm
    this is a very interesting find you have come across
    and it is great to see you have shared it with quiet a few people in this forum
    very nice
    cheers
  3. #103
    Jan 2007
    5
    Smile Servo Motor Controller
    Hi Everyone ,
    I have collected all the parts needed to build my servo driver. Should I just insert the tiny2313 directly and start running the motors ? OR DO I HAVE TO PROGRAM THE ATTINY2313 ? IF PROGRAM THEN PLZ GUIDE ME TO SOURCE [email protected] - [email protected]
    Love You All - Fellow Hobbiest
    GSM
  4. #104
    Feb 2007
    31
    Quote Originally Posted by gsmgsm View Post
    Hi Everyone ,
    GSM
    Hello!
    Source co can find upsteirs in forum. Also do not foget about fuses. Read all carefully. Because of Mike Everything is OK.
    Regards
    Alex.
  5. #105
    Dec 2006
    18
    Quote Originally Posted by alex751 View Post
    Hello!
    Regards
    Alex.
    Hi Alex,
    Sorry for late answer. Your point about R2 and R3 values made me check the schematics again, and I saw the point.
    When you look at the schematics from http://elm-chan.org/works/smc/report_e.html (namely circuit diagram for smc3/a and High Power Drive) those resistors are not necessary... My mistake.
    The High Power Drive schematics of elm-chan.org is almost the same with the UHU power drive part posted by smarbaga. 1st pins of IR2184s is directly connected to OC1A and OC1B pins of AtTiny2313. I will update the schematic and upload it again.
    I also added max232 for communication.
    But I haven't made the pcb. I could not find IR2184 chips in electronics stores in my city, will check from another city.
    Hope this helps.
  6. #106
    Mar 2005
    523
    hello
    these ir2184 fet drivers chips are quite hard to find and are expensive.
    i wonder if there is another fet driver chip, more common and less expensive that can replace these ir2184's.
    like the TC4426 or mc34151, any other sugestions?
  7. #107
    Feb 2007
    31
    Quote Originally Posted by smarbaga View Post
    hello
    Hello
    Fet driver 2184 cost about 1 USD. I think it is not so expensive. You can cange it with discrete elements. Just download 2184 datasheet and make due to functionla shematic.
    Regards
    Alex.
  8. #108
    Feb 2007
    31
    Hi Alex,
    Hope this helps.
    Hi!
    I think resistors needed for pullup or to decrease a nose. so shematic looks like mine. This evening I had started with my controller but I have an errors. I need to change parameters. Also I am not sure in my encoder.
    Regards to Mike. Thanks for help.
    Regards to all.
    Alex.
  9. #109
    Feb 2007
    31
    To GSMGSM
    This link is to download al set of file.
    http://rapidshare.com/files/18777408/smc_dc.rar.html
    What kind of programator you have?
    Regards
    Alex.
  10. #110
    Mar 2005
    523
    hello
    hummm, where do you get those 2184 drivers for $1.00.
    i was talking to a supplier just yesterday that wanted $12.00 each for them.
    digikey wants $4.50 each. the last tube i bought (50 pcs) i got directly from
    international rectifier, a little less than $4.50 each. + $12 shipping.
    i have attached another h_bridge design,
    i have not tested it yet as i don't have the fet driver chips.
    all comments and sugestions would be greatly appreciated.
  11. #111
    Sep 2005
    167
    where can i get a copper layout for that board ?
  12. #112
    Mar 2005
    523
    hello
    i could draw one for you.
    but i don't know if it will work. (as is )
    i was waiting for someone to say it needs some
    conditioning or something like that,
    because it looks to simple to work.
    fet on and off delay times could be adjusted in software
    to match different fets,
    the fet driver sells at digikey for $2.00 and is 3 amps o/p.
    i think a perf board to prove the consept would be a good idea
    just incase it needs somethig.
    but a layout can always be modifyed.
    i will try to get a layout of this cct on here tomorrow night.
    unless the water pipes freeze or something . :-)
  13. #113
    Feb 2007
    31
    hello
    Hi! I am sorry not 1 USD but 2 UDS you can check my supplyer
    http://www.kosmodrom.com.ua/product....=0&name=IR2184
    This is in russian but you can divide 11 by 5,5
    Regards
    Alex.
  14. #114
    Sep 2005
    167
    thanks smarbaga, i will sure be waiting for it
    but what the max rating that drive can handle ?
    anyone tried it ?
    thanks
  15. #115
    Jan 2007
    5
    Hi Alex
    I hv downloaded the AVR STUDIO 4. Thanks For the Files . Please guide me further, How can I edit the codes, just in case if my motor is different from which u have, Wht to change and how ? .... Looking Forward for ur Sweet Reply....
    Regards
    GSMGSM
  16. #116
    Oct 2005
    36
    elm & power mosfet
    Quote Originally Posted by max_imum2000 View Post
    Hello all .
    I have files of elm smc&smc3a & power mosfet protel pcb and pdf .
    Regards,
    nasr1
    Attached Files Attached Files
  17. #117
    Mar 2005
    523
    hello
    i managed to get some time to lay out a driver board for a design that i think might work.
    attached is the schematic and pc board layout.
    this has not been tested yet and the current monitor is not on the layout.
    as usual, your sugestions are greatly appreciated
  18. #118
    Nov 2005
    105
    anyone have made a set and fully functional ? or still in testing phase?
    Live life like you never see another day
  19. #119
    Feb 2007
    31
    Hi Alex
    Regards
    GSMGSM
    So fist tell me what kind of programmer you have? I mead AVRISP STK200/300 STK500 ??
    Regards.
  20. #120
    Feb 2007
    31
    Quote Originally Posted by NASR1 View Post
    Hello all .
    Regards,
    nasr1
    Hello Nasr1!
    What kind of software you have used to trace your layouts??
    Regards
    Alex.
  1. Central PID Controller vs. PIV Controller in each Servo Amp
    By Bronx68 in forum CNC Machine Related Electronics
    Last Post: 11-20-2013, 05:33 PM
  2. Servo Controller pin out ?????
    By slowtwitch in forum Servo Motors / Drives
    Last Post: 05-28-2013, 03:55 PM
