Originally Posted by
Rob_M.
Geof and Gar,
You are correct and I am aware of that. We do a lot of hogging, so when the machine bogs down it's rather annoying, we've learned to live with it I guess it would be "nicer" if 100% spindle load meant 30hp.
![Smile](images/smilies/smile.png)
In all reality for the cost of the machine it works really well.
Normally I machine aluminum and find they perform very well. On steel it is different and one compromise solution I use on a SuperMinimill when I am dealing with hot rolled steel is to go fairly high speed, smallish depth of cut and a good feed with a small face mill using an air blast.
But it is not a good choice of machine for steel I think.
