587,482 active members*
3,631 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Making you own DYI rail for linear blocks
Results 1 to 8 of 8
    Aug 2006
    19
    With so many linear blocks sold with rails too short, or sold with no
    rails, or the need to improve the lengths of items that you already own;
    has anyone tried to cnc their own rails to match blocks that they have?
    Is their a definite reason why this would not be possible?
    Any thoughts?
    java77man
    Apr 2005
    3634
    Quote Originally Posted by java77man View Post
    Any thoughts?
    java77man
    Might need to harden & grind, after you machine the rail.
    Jan 2004
    3154
    Of course it is possible.
    To make rails of the some quality and precision will easily cost more than 10 times purchase price.
    They are hardened and ground to within .0001"
    Rails can be mounted end to end with a proper joining block and it will cause no problems.
    www.integratedmechanical.ca
    Apr 2007
    1955
    The newbie in me was really hit tonight with why people here spend so much time thinking about home made rails / bearing setups. It does not happen often, but I was really hit with sticker shock on bearing prices - wow.
    Kind of set me back in my chair on this hobby.
    Apr 2005
    3634
    It can still be done (cnc router) & be affordable.
    You have to be creative in the parts you have to work with.
    Mar 2004
    94
    This is the hangup for a lot of people.
    Round linear shafts are relatively cheap, but can't go very far without middle support. Combine that with the home-brew roller blade bearing setups, and you probably have something approaching the fluidness and tolerances of commercial linear bearing.. but you'll spend a lot of time dialing them in... and I doubt they can handle the same loads.
    That's my plan for my next machine... hope to build it for under $200.
    check out some v-groove bearings , they are cheap and can keep a slide setup relatively simple
    Nov 2005
    62
    I plan on useing 1" rod on top and bottom of a 3" c-chanel with roller blade bearing setups to spaned 96" should be strong and cheap
  1. What size ball bearings for linear blocks?
    By Zumba in forum Linear and Rotary Motion
    Last Post: 05-19-2006, 06:22 PM
  2. Guide Blocks or Linear Shaft?
    By mre1000 in forum DIY CNC Router Table Machines
    Last Post: 11-21-2005, 01:38 PM
  3. Linear shaft mounting blocks
    By WarrenW in forum DIY CNC Router Table Machines
    Last Post: 10-27-2005, 04:01 PM
  4. Linear Pillar Blocks
    By js15 in forum DIY CNC Router Table Machines
    Last Post: 07-20-2005, 05:03 AM
  5. Making your own pillow blocks and Rail mounts?
    By Zephrant in forum DIY CNC Router Table Machines
    Last Post: 05-20-2003, 12:34 AM
