587,180 active members*
4,133 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > idea for limit switch, need opinions
Results 1 to 3 of 3
    Jun 2004
    201
    I have hundreds of these magnetic reed switches from another project and I was thinking of using them as limit switches.
    The reed gets placed where the switch normally would go, and the magnet can be simply stuck any where on the tables or head depending on where you want the limit to occur.
    I was thinking that especially for the z axis where your end mill length varies, this would be very good. You simply lower your head untill your end mill is at its maximium depth you would want it to travel to, then slide your magent down untill you trip the switch.
    I think this also covers such things as moisture and dust getting into the workings of the switch.
    The only thing that would need to be looked after is debree sticking to the magnet it self. This will not interfere with the magnets operating distance, but would be the only thing that required cleaning.
    Total cost of switch and magnet is only $3
    Jun 2007
    190
    The reed switch & magnet are quite convenient for setting temporary limits, especially on the z-axis where you can usually keep the magnet away from the work area.
    Feb 2007
    11
    I would not use magnets, as they will collect to much swarf and become unreliable. Also, if you are using these switches for limit (SAFETY) switches you want extreme reliability. If you are using them for HOME switches they will not be accurate enough and will have poor repeatability. I would get some decent micro-switches, or some hall effect switches
  1. Solid-State limit switch experiment
    By Swede in forum CNC Machine Related Electronics
    Last Post: 01-08-2010, 08:20 PM
  2. Opinions on an idea =)
    By Epik in forum Community Club House
    Last Post: 03-02-2005, 11:47 PM
  3. limit switch override
    By swarfmacdaddy in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-12-2004, 10:47 AM
  4. Alternative positioning idea.
    By ynneb in forum DNC Problems and Solutions
    Last Post: 02-19-2004, 05:54 PM
  5. Enclosure idea - need opinions
    By jgro in forum DIY CNC Router Table Machines
    Last Post: 02-16-2004, 11:56 PM
