587,418 active members*
3,506 visitors online*
Results 1 to 9 of 9
    Sep 2006
    4
    Thread Milling on a 5 axis lathe
    hi there,
    We are trying to thread mill 1/8 - 27 NPT on a 5-axis lathe. Most of the software out there would only output code for a machining centre. Our lathe will only accept J & K. XYZ axis on a mill but on a lathe X (diam) is the tool axis. Any help would be appreciated.
    Thanks in Advance
    May 2006
    214
    HI there -
    I'm having a hard time myself understanding this thread mill business.
    But in a lathe why not G76 thread cycle...just wondering.
    Cheers
    Jorge
    Jul 2005
    12177
    Quote Originally Posted by Jr. Programmer View Post
    hi there,
    Thanks in Advance
    Which axis is the thread rotating around?
    EDIT: Silly me you mentioned it X is the tool axis you say.
    I don't use software but this should be possible. Get your code output which has X, Y, Z, I and J and then do a Find and Replace in a word processing program:
    Z will become X
    X will become Z
    Y stays the same
    J stays the same
    I becomes K
    Your tool is moving in the Y, Z plane and advancing along the X axis. (I think)
    Sep 2006
    4
    I believe G76 thread cycle would be used for ID threading of a cylindrical part. I need to thread mill perpendicular to the the z-axis (ie. the top of the part).
    Sep 2006
    4
    hi Geof,
    I hear ya..but on a lathe X is the diametrical which means (Z x 2 in diameter). Having said that, does the J and K change accordingly? If so how much? These machines are not quite simple as a 3 axis mill...
    Jul 2005
    12177
    hi Geof,
    No not quite as simple .
    I don't think this would have any effect on J and K and it could be as simple as using a G code to shift the X axis from diameter measure to radius measure. If I was designing a machine that could turn and mill I would incorporate this feature.
    If there is no way to command this then you might have to generate your code using twice the pitch so when you swap the Z and X you have compensated for it.
    Also if you are just using three of the axes and they are orthogonal then you have a three axis machine.
    Jan 2006
    4396
    hi there,
    Thanks in Advance
    In theory you can Interpolate a Helical Thread on a 5 Axis Lathe. But you need a true Y and C Axis to do this. Also you will need to find the G-Code Designation that will Synchronize the C Axis with the Y Axis. What this will do is replace the Y Axis with the C Axis. Maybe a G100, G101, G120, G121, G200, G201, G300, or G301. You may also have to Designate a Work Plane.
    This is still a 3 Axis movement but in the C, Z, and X Axies. It is the Same as an XYZ Movement but you are substituting the Y for the C and the X is now your Depth in the part.
    What Machine, and Control Are you trying this on??
    I have done this once before on a Nakamura-Tome. I will try to find the Program so you can see it.
    G76 to my knowledge is only used for the XZ Plane, G18.
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    May 2006
    265
    G90 G19
    S6853 M3
    G00 C0.000 Y0.0000 Z0.0000 X0.0787 Position to centerline of thread/ 0.0787 above surface
    G91 - incremental
    G00 X-0.3692
    G41 G01 Y0.000 Z-0.1555 F39.0640
    G03 Y0.000 Z0.3480 X0.0185 J0.000 K0.1740 F3.5304
    G03 Y-0.1928 Z-0.1925 X0.0093 J-0.0001 K-0.1926 F7.5084
    G03 Y0.1928 Z-0.1931 X0.0093 J0.1929 K-0.0001
    G03 Y0.1934 Z0.1931 X0.0093 J0.0001 K0.1932
    G03 Y-0.1934 Z0.1937 X0.0093 J-0.1935 K0.0001
    G03 Y0.000 Z-0.3492 X0.0185 J0.000 K-0.1746
    G40 G01 Y0.000 Z0.1555
    G00 X0.2952
    G90
    This should produce a 1/8 npt in you machine.
    Hope it will be of any help...
    Jul 2003
    263
    Quote Originally Posted by tobyaxis View Post
    On machines equipped with FANUC controls G12.1 allows you to use the C axis as the Y where you are using polar interpolation to cut your part. the only problem with using G12.1 is you have to be in G1 mode at all times no G0 is allowed in your tool paths. all positioning have to be done in G1 mode. G18 plane should be active to use G12.1. the other problem using G12.1 is you have to cut at X0.
    If you can ENVISION it I can make it
  1. thread milling
    By fourperf in forum Fadal
    Last Post: 03-11-2008, 01:14 AM
  2. 0M-Thread milling?
    By mikul in forum Fanuc
    Last Post: 12-06-2006, 06:56 AM
  3. EdgeCam 10.5 Y axis milling on lathe ?
    By tricky in forum EdgeCam
    Last Post: 07-13-2006, 05:17 PM
  4. thread milling
    By DavidC1949 in forum G-Code Programing
    Last Post: 03-30-2006, 07:27 PM
