588,461 active members*
5,001 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Activating the waylube pump ?
Results 1 to 7 of 7
    Mar 2005
    143
    Guys,
    Is there some secret command or debug option to activate the waylube pump ? I just want to be sure all the lines are flowing.
    Thanks!
    Feb 2007
    67
    Good question...
    We had some way-lube issues on our 4020 a while back and if I remember correctly it is based on movement of the ways ...and I am having a brain-burp here...but I think it lubed every 4? minutes of operation...I think we just programmed in a really slow feed over a long distance and fired the spindle up too and let it run until it hit whatever time/logic period is was looking for. But, that is an old '93 4020 so who knows. It has a manual lever to pump as well and that was great to check it immediately but there should be a secret-shake or code that you could activate the electric pump portion and insure continous function, but I don't know of one. I do know that the way lube manifold located under the left end of the table ( as you are facing the machine) was a crumbling piece of scrap and had several cracks. If your machine is older that part may need addressing and it is not an expensive replacement...does come in at least 2 variants though for number of lines.
    I know I didn't help much but that's just something I remembered from a while back.
    Apr 2005
    1194
    If its an older pump they have a aluminum piece sticking out that you can adjust. These pumps are a basic Bijor pump and lube when the static pressure reaches 500psi (I believe its 500). It sounds like your machine farted wen they go.. One way o tell is to watch the way cover in front of your Z axis and look to see if their are small oil puddles gathering.
    Jul 2006
    67
    Way pump
    Ive noticed on several fadals that that lube pump dont like to work.On ours,When I fire the machine up,I manually pump it untill I see oil in all the lines.clean the filter in the bottom,as it gets full of wax and check all the metering units to make sure they still work.You wont like this,but way lube has lots of wax in it and certain coolants will make it seperate and plug up the grooves in the turcite.
    "If you do what you always did,you'll get what you always got."
    Apr 2005
    1194
    I dont think Vactra 2 has any wax in it I think your problem might lurk elsewhere. We had disastrous results from using a vactra 2 substitute...I would only suggest Vactra 2 for Fadal applications and Vactra 4 for much larger machines.
    Aug 2008
    3
    on the 1100-2 board you can unplug and plug back in the k19 relay which will activate the waylube pump, or you can, on some with the solenoid mac valve on top of the pump grab a small allen wrench and activate it , by pushing on the solenoid manual test button
    Jan 2004
    3154
    Quote Originally Posted by alexacosta82 View Post
    We have a winner!
    Yes - push and hold the manual activator on the solenoid. once you see the pressure gauge stabilize - let it go. Repeat as desired.
    www.integratedmechanical.ca
  1. 325 Coolant Pump
    By TurtleRacing in forum Tree
    Last Post: 04-02-2012, 07:51 PM
  2. Fadal4525 Waylube Pump
    By toolrm in forum CNC Machining Centers
    Last Post: 01-11-2007, 03:53 PM
  3. Waylube pump upgrade
    By AndyB in forum Fadal
    Last Post: 06-10-2006, 03:25 AM
  4. Activating HPCC in a sub-routine?
    By Dawson in forum Daewoo/Doosan
    Last Post: 03-18-2006, 09:04 PM
  5. servos not activating
    By Chris81579 in forum DNC Problems and Solutions
    Last Post: 03-11-2006, 09:09 PM
