587,833 active members*
3,302 visitors online*
Results 1 to 10 of 10
    Sep 2007
    13
    Unhappy Dripfeed Matsuura
    How do i drippfeed my matsurra mc500-v.
    I use Cimco to send program.
    How do i prepare the machine for rechive. I think i should use the tape mode. But how do ill start the machin for rechive?
    Please help me.
    2932
    What control does it have?
    Sep 2007
    13
    The control is Yasnac
    2932
    Great. Which YASNAC? M5, M5-G, M5-GII, MX1, MX2, MX3? I believe the later ones could drip feed, the earlier ones couldn't.
    Sep 2007
    13
    Im not sure but, i think it is a mx 2.
    I think one of my machines is a mx3
    I have the following models of matsuura with yasnac
    VX-1100
    RA-1 With pallette.
    MC500-v
    Sep 2007
    13
    Two of my machines has MX3- And one of em has MX2
    2932
    Try this. Put the machine in Tape mode. Turn on the Single Block switch. Hit Cycle Start. LSK should blink? From the PC, send the program. At NC, turn off single block, hit Cycle Start. (It's only been 25 years or so since I last did this, so my memory is a little fuzzy.)
    Sep 2007
    13
    Thanks, it help me alot. Now the machine is rechiving something, but ill get an alarm with overun. Ill think it is a settings. But now i have something to work with.
    Thanks alot.
    Martin
    Sep 2007
    13
    Working perfect now. I was cheatet because the screen dosent show anything while running in tape mode. Cant u see the program from the computer while it running. So u can see what the machine will do next?
    Thanks,
    check and see if the software has a terminal mode than you can see the data output but it will be buffered in the machine
  1. Bridgeport R2G4 Dripfeed from mastercam
    By leeputman in forum Bridgeport / Hardinge Mills
    Last Post: 05-06-2007, 03:41 AM
  2. File size limit??? Dripfeed??
    By jsatter in forum Centroid CNC Control Products
    Last Post: 01-31-2007, 06:22 PM
  3. Dnc dripfeed for Dynapath Delta 10
    By badgs750 in forum DNC Problems and Solutions
    Last Post: 05-21-2006, 07:37 AM
  4. Fanuc 10m dripfeed (DNC)
    By mroy0404 in forum Fanuc
    Last Post: 10-10-2005, 12:27 AM
