587,834 active members*
3,116 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Rookie Question...3 axis vs 4 axis controller
    Oct 2007
    31
    I am considering building my first CNC machine and have seen several designs that use 2 motors on the X Axis. I would like to use this design approach. My question is are these two motors generally wired in parallel using a 3 axis controller, or is a 4 axis controller used and it treated as a fourth axis and programmed the same as the third axis?
    35538
    Use a 4 axis drive, and let the control software slave the second X motor to the first. Mach3 has this capability.
    Oct 2007
    31
    Gerry,
    Thank you for the information, I will go the 4 axis route.
    Thanks again
    Kevin
    May 2009
    7
    I have just built a gantry style machine, I run the "y' axis with 2 motors. You slave the "A" axis motor off the "Y" .This is done in the Mach3 config settings.
    enjoy
    Burt
  1. 4 axis controller
    By pump in forum Australia, New Zealand Club House
    Last Post: 08-11-2007, 05:16 AM
  2. Need Help With 3 Axis Controller
    By jeffg in forum Machines running Mach Software
    Last Post: 03-29-2007, 09:05 PM
  3. 4 axis controller for 3 axis machine?
    By tybrenis in forum Community Club House
    Last Post: 01-20-2007, 04:12 AM
  4. 3 axis stepper motor controller board - question
    By Yellowbeard in forum Stepper Motors / Drives
    Last Post: 04-07-2005, 04:02 AM
