588,385 active members*
5,481 visitors online*
Page 1 of 2 12
Results 1 to 20 of 22
    Aug 2007
    9
    ACME Leadscrew question
    I am new to CNC and have been lurking around for 2 or three months just taking everything in and deciding what type of machine to build. I have already ordered the HobbyCNC 305 kit. I am wanting to order the ACME lead screws for the machine but there are many different materials that they come in. For example:
    Taken from McMaster-Carr (6 foot length)
    Type 316 stainless steel $ 93.87
    Zinc-Plated $ 26.55
    Grade B7 Alloy $ 38.40
    18-8 Stainless Steel $ 59.55
    Plain Steel $ 11.48
    The Type 316 is way out of my budget, but the others are doable.
    What is the most cost effective solution for a home built CNC?
    Thanks for checking out my question, this is a great place for CNC info.
    Feb 2007
    20
    this is what i used:
    http://www.use-enco.com/CGI/INSRIT?P...&PARTPG=INLMK3
    1/2"-10tpi 6ft $6.99
    May 2005
    362
    I'm with Heritage... I bought 4 of those carbon steel screws from Enco and at half price you can't go wrong. Excellent accuracy and practically no backlash. An excellent value. Save your money and buy the $6.99 Acme.
    Oct 2004
    727
    Welcome to CNCzone, whmeade10.
    Pick whichever one fits into your price range. I'd go with a tighter tolerance ACME lead screw over a 'pretty' looking one if your going to spend any extra money. If your CNC table is going to be constructed from wood or plastic I'd just buy the cheapest one and be done with it. The cheap plain steel one is working fine for me.
    I concur with HeritageAmps and txcowdog, I too purchased my lead screws from ENCO and have no regrets concerning the performance or the price. Spend the money you saved on the ACME screws to purchase lead nuts from DumpsterCNC. In my opinion they're hard to beat.
    Whatever you do, stay away from the plated lead screws. If the plating starts to come off (and it will) you're going to start having all kinds of problems with wear and backlash.
    Good luck with your build,
    HayTay
    Don't be the one that stands in the way of your success!
    Jul 2007
    31
    Hey guys,
    The different types of steel of the ACME lead screw of course gives different rating for "strength." Of course unless your machine is going to be real heavy or is rated for a lot of cutting force, you shouldn't have to worry about that. Any of those grades will be sufficient strength wise.
    Where the grade of the steel has a more pronoun effect on the friction it will cause between the lead screw and the lead nut.
    More friction = Less effective power that your stepper/servo motor will deliver to your system. Or in other words the more friction, the less efficient your CNC router will be and it could lead to your motors wearing out sooner.
    But, the good news is that most of those steels will all have similar coefficients of friction. As a good general rule to go by is the prettier it looks, or the shinier it is, the less the coefficient of friction will be.
    The is important if you your lead nut (the nut going on the lead screw), is steel or bronze. A stainless steel lead screw on a steel nut will have a lower coefficient of friction than a B7 grades steel.
    You can look up coefficients of frictions between two material on Google. The LOWER the number, the better. This can be important between two materials as some have a tendency to stick( high CF), and can cause you to have a fair amount of power loss. If you stepper motors are already undersized or close to it, this can cause your machine to bind at high speeds or under the cutting force.
    If your lead nut is a bronze or brass, then there will be little difference between any of those grades and the bronze. They will all have very similar coefficients of friction.
    What I suggest is using an ani-backlash nut. The cheapest ones are the ones from dumpsterCNC.com. as mentioned above. I have used his products on several of my machines and have never been disappointed. He even offers custom hole patterns for and extra $2.00.
    The material he uses is called Delrin or Acetal, the coefficient between delrin and any steel is much lower than even bronze and any of those grades will work fine, so go with the cheapest.
    What you should be more concerned about is the type of lead screw not the material. Some of the ones you have listed from McMaster-Carr are called rolled ACME leadscrews.
    Also called precision leadscrews and that is why the prices are so high and not the material.
    Rolled or precision ACME rods are made for linear motion and thus are more expensive and will have less backlash. However, if you use an anti-backlash nut, like the ones from dumpster. You will do just fine with the plain steel ACME rods that are formed and not rolled. I have made several machines this way and have achieved accuracy and precision of .0005 repeatable. You lead nuts will tend to wear out faster but for the price at which dumpster sales them, its still cheap just to replace them in a couple years lol.
    I hope I haven't confused you. I have made several machines of my own. I also own a new website that is still in progress. We started uploading it this week.
    Its cncroutersource.com and you can find all this information and much more, and its all free. There is a complete CNC router builders guide that will give you all this kind of information and more. But bear with us as we upload it all, and of course its all free.
    We break down every part of a homemade CNC router and walk you through the whole process.
    My name is Brian and I am a mechanical engineer who does this stuff for fun lol. If at any time you have any questions. you can contact me or someone at our site with any questions and we will get right back to you!!
    I hope i helped. Be patient and HAPPY CNC'n.
    ~Brian
    [email protected]
    Aug 2007
    9
    I would like to thank everyone that responded to my question. I believe I will go with the plain steel ACME lead screw and the ani-backlash nuts from dumpsterCNC.com for my first CNC. I am already thinking about my second one and the first one isn't even built yet. Is this normal
    My CNC design is based on the JGRO CNC. I say based because it will be made out of steel and aluminum. I will start a build log thread in the CNC Wood Router Project Log when I get along a little farther.
    I went and checked out your site Brian, and I have to say, it looks great so far. I have book marked it and plan to go back and check everything out. Keep up the good work. I can't get to much info :banana:
    Dec 2006
    532
    buy 42 feet of acme rod and get free shipping!!! Enco free shipping code for orders over $50:
    WBCT7
    Expires Oct, 31 2007 But new code should be available in few days
    Jul 2007
    31
    whmeade10,
    Glad to hear you are excited about the project. I will try and keep posted on your progress. I do not think you can go wrong with the plain steel ACME rods and the anti-backlash especially for your first machine.
    Its very normal to start thinking about your next machine. If all goes well you can use your first machine to help build a much nicer second machine.
    So, keep in touch and just shoot us an email if you need any advice or help and of course use the threads on CNCzone.
    Just so you know you can also bye a 6' ACME threaded rod from Mcmaster for $6.50. Its listed under ACME threaded rod and not the lead screw section. Part # 93255A431. I have used both Enco and Mcmaster and they both are great companies. So either one is good, just which ever is cheaper and offers the cheapest shipping.
    You may also want to think of anything else you need so you may buy it all at once, if you have the funds all at once. That will save you some money on shipping charges.
    Good luck!
    [email protected]
    CNCroutersource.com
    Brian@cnc
    Oct 2007
    3
    What is the difference between 2 start and regular acme treads. Any advantages? It also seems as if most people are using the 1/2 dia. I would like to do a double screw lay out with the 3/8 dia. Is it a power transmission issue? I have the hobbycnc 305 stepper kit on order.
    35538
    2 start is much more efficient, and also keeps the steppers spinning slower, where they have more torque. When you factor in the added efficiency and the motor having more torque from spinning at 1/2 speed, when you switch from 1/2-10 1 start to 1/2-10 2 start, you basically double your speed, and still have nearly the same force at the screw as you did before, so other than the added cost, it's a no brainer.
    The reason most people use 1/2", is because its 1) cheap. and 2) 3/8 is not really useable in longer lengths due to whipping at higher rpm's.
    Oct 2007
    3
    Thanks for the info. I have also been considering rack and pinion for the x/y axis. any thoughts on this?
    Jul 2007
    31
    More on Lead screws
    Here is the technical definition.
    Starts—The number of independent threads on a rod or stud. All general purpose Acme rods and studs are single-start. Precision Acme rods are most commonly single-start, but also come in multiple-starts, which allow the nut to travel faster by moving farther in one turn.
    Now and explanation,
    The more starts the machine will travel faster by moving farther in one turn. Also, the more starts the less likely there is for backlash but you still need an anti backlash nut. Think of a 2 start has double the threads than a 2 start, its almost like having 2 lead screws in one or two nuts as there is twice the amount of contact between the nut and the lead screw.
    Another way to think of it is like this,
    A nut on a 3/8-10 1 start lead screw needs to turn 10 times in order to travel a distance of 1 inch on the lead screw.
    A nut on a 3/8-10 2 start lead screw needs to turn only 5 times to travel a distance of 1 inch because there are double the amount of threads.
    So to find the amount of actual machine travel take the turns per inch (TPI), like the 10 in 3/8-10 and divide by the amount of starts and that’s the amount of travel you will have.
    Multi start lead screws are usually more expensive. If the rod itself is not more expensive the nut will be. However, if your budget allows and you can find the anti-backlash lead screw, then it would be best to go with a 2 start over a 1 start, but there are trades that you need to make.
    Many people go with a ½-10 lead screw for many reasons
    1) Its readily available
    2) Anti-backlash nuts are relatively easy to find
    3) They are pretty cheap
    4) It’s a good trade between mechanical advantage and speed
    Speed, linear force, and the span the lead screw will go are 3 trades that will decide you lead screw diameter and turns per inch (pitch).
    First let’s look at the trade between the linear force mechanical advantage and the travel speed. The travel speed will directly determine your cutting speed which is rated in inches per minute for CNC routers (IPM). Many people do not care about the cutting speed when they build their first machine and then later get tired of their machine only moving at 20 IPM. The lower the IPM rating of your machine the longer it will take.
    The cutting force is how much force your machine will have when cutting a piece, remember, just the movement of the machine itself will require some force. If you have a nice linear motion system with some sort of linear bearing (rails and bearing blocks, homemade linear bearings from radial bearings etc) then it should not take much force to move your machine.
    For example let’s say the y and z axis gantry assembly of your machine weighs lets say 40 lbs, and you have some sort of ball bearings for your linear bearing system. Since the coefficient of friction for ball bearings is around .02 and you will have 2 linear systems for each axis, it would only take about 1 lb to move your gantry assembly. The rest of the force would be the cutting force.
    The pitch of your lead screw or the TPI of your lead screw will determine both of the speed and the cutting force.
    The more turns per inch of a lead screw means there will be more mechanical advantage and MORE cutting force but LESS speed.
    The less turns per inch means MORE speed and LESS cutting force.
    If you have the 305 kit, you have 4 steppers and I’m guessing will be putting 2 steppers on the x axis. This is 610 oz on the x axis which is the longest axis. Depending on the size of your machine, your will probably not need a mechanical advantage of a ½-10 lead screw.
    So I would go with a 10 tpi and 2 starts or an 8 tpi 2 start. In this case speed will be better than cutting force.
    Remember that the rating at 305 oz is rated at 0 RPM’s of the stepper motor. Stepper motors have the most force at 0 RPM’s.
    This brings us to the second consideration the span. Stepper motors max RPM may be anywhere from 800 to 1500 RMP’s. Let’s say you are using micro steps and your stepper motor max RPM is 500 RPMs because the torque of the motor drops off too much after that.
    With a 3/8-10 2 starts you have 5 turns per inch and at 500 RPM your machine will travel at 100 IPM which is pretty good rating for a hobby CNC.
    500 Revolutions per minute
    --------------------------------- = 100 Inches per Minute (100 IPM)
    5 Revolutions per inch
    This would still leave you a lot of cutting force so that if you were cutting a very hard material, you would be less likely to bind and have your steppers miss steps.
    But there is bad news at 500 RPM’s a diameter of 3/8 inches would want to “wobble” over spans larger than 36”. No matter how good we are nothing is perfectly lined up.
    So if your machine is small, a 3/8 diameter would work, but if the span of any axes spans more than 36” (48” MAX) I would strongly recommend that you go with a ½ inch diameter lead screw. Not because of the force, but rather because of the risk of the lead screw whipping and wobbling at higher RPM’s.
    My suggestion would be use a ½-10 2 start lead screw and avoid this conflict all together.
    You can buy anti-backlash nuts for this at dumpster CNC and its only a couple bucks more than a 3/8-10 2 start nut, they even offer a ½-10 5 start (really fast).
    However, its hard for me to say without knowing the size of your machine, and if you have 2 lead screws on the x axis and it does whip and wobble, it will be twice as bad.
    You can find all this information and more at my website http://www.cncroutersource.com/ and it’s all free. Check out the builders guide section http://www.cncroutersource.com/homemade-cnc-router.html Book mark it and be patient as we upload the pages. The website is only a few days old.
    You can send me your design specs and I can give more detailed advice. Just send any questions or anything to [email protected]
    P.S
    To find how much linear force you will get from your lead screw and motor assembly, use this formula.
    1. Convert ball screw/lead screw turns per inch to pulley radius:
    Example:
    ½-10 2 start = 5 turns per inch convert this 1 inch/5 turns per inch = 1/5= .2 = pitch
    So pitch = .200
    Then divide pitch by 2pi or 6.28
    Example:
    0.200 / (2pi) = 0.200 / 6.283 = 0.0318" (equliv. radius pully)
    2. Convert motor torque into linear force: divide torque of your motor by the puller radius
    example:
    Torque = 100 Oz.-In.
    100oz-in / .0318 in = 3144 oz. (linear force)
    3144 / 16 = 196 lb (linear force)
    3. Multiply result by the efficiency:
    ball screws have efficiency of 0.8
    Acme Lead screws have efficiency of about .6 (for a Acetyl nut on a steel lead screw)
    196 * 0.6 (efficiency for ball screw) = 117.6 lb linear force.
    35538
    Quote Originally Posted by gth629e View Post
    Also, the more starts the less likely there is for backlash but you still need an anti backlash nut. Think of a 2 start has double the threads than a 2 start, its almost like having 2 lead screws in one or two nuts as there is twice the amount of contact between the nut and the lead screw............................
    Not sure how your less likely to have backlash. You do NOT have double the number of threads or twice the contact, they are both the same.
    Where as a 1 start 1/2-10 screw has one 10 turn per inch thread, a 2 start has two alternating 5 turn per inch threads. Both have 10 threads per inch.
    Jul 2007
    31
    Hello,
    Thank you for calling out this statement it is misleading the way I stated it. I did not mean to imply that there were twice the amount of actual threads. What I meant is that there are as you stated "2 alternating threads". I was only trying to get this point across.
    There are 2 relative points of contact on a 2 start rather than 1, for the same lead. The total area of contact between the nut and the lead screw is doubled. This allows less room for backlash.
    This is basic linear motion design consideration. If you do not trust my source check out this http://www.roton.com/identify_threads.aspx. Scroll to the bottom where it talks about starts.
    "Also, for the same lead, increasing the number of starts actually increases the thread contact area when compared to a thread with the same lead but using fewer starts and a coarser pitch"
    I have been designing linear systems for a while and know this to be a fact. You may cross reference this in the machinist handbook as well if you own one.
    Hope this clarifies
    As to the rack and pinion question,
    rack and pinions are great in some applications. They can be a little harder to setup correctly. You must install them in a way that does not allow chips to fall into teeth of the gears. If you do go with a rack and pinion setup, try and use a helical tooth pattern. This allows more teeth of the gears to contact between the rack and pinion. This will help with accurace, precision, and will help sustain the life of your rack and pinions.
    Hope this helps,
    Brian
    [email protected]
    35538
    There are 2 relative points of contact on a 2 start rather than 1. The total area of contact between the nut and the lead screw is doubled. This allows less room for backlash.
    Sorry, but it's not when comparing 1/2-10 one start to 1/2-10 two start. Your other quote backs me up.
    When they say the "same lead", that would be equivalent to comparing 1/2-5 one start to 1/2-10 2 start. Both are 5 turns per inch. In this instance, you'd be correct. But when both are 10 threads per inch, Which I said in my other post, you are incorrect. Both have 10 threads per inch, and both have the same contact area.
    Jul 2007
    31
    Hello,
    Yes for the same lead, increasing the number of starts increases the contact area. This is the case I was talking about. I did mean to say 1/2-5 1 start and 1/2-10 2 start (same lead).
    When you say that more starts do NOT equal more contact area is an incorrect statement.
    Once again sorry if I "confused" anyone. The point was, the more starts are the better choice for this application. Which is, i believe, what we are both saying.
    I will be more diligent on my posting and read through it thoroughly before submitting. I only wish to help. Thank you for catching my mistakes. Engineers are not often known for their communication skills lol.
    Brian
    [email protected]
    Oct 2007
    3
    Thanks again for the fantastic feed back.
    Jul 2006
    1256
    GYH629e
    Maybe off topic,but has to do with Acme.I have a ground THK E-Bay ballscrew dia20mm lead 5mm per turn.As I understand for the Z axis this unit will backdrive and require counterbalence springs,brakes,or air cylinder to prevent the spindle crashing into the spoilboard.A class C Acme will not backdrive?May it be a better choice and cost effective?
    BTW love your site,www.cncroutersource.com
    Larry
    L GALILEO THE EPOXY SURFACE PLATE IS FLAT
    Jul 2007
    31
    Larry,
    Do you mean backlash or back drive? Backlash is the play between the nut and lead screw. Do you know the rating on your THK ball screw? Some are pre-loaded and contain less "backlash" than others. As with any system, both parts play a role in quality. Both the nut and the lead screw can play a role in backlash.
    Back drive is the tendency of the Z-axis plunge arm to coast back down when supporting a vertical load (the router). The tendency to back drive in the vertical will depend on several things, weight, pitch of lead screw, holding torque of stepper/servo, efficiency of lead screw/ ball screw, and the friction of the linear bearings holding that assembly.
    When you hear of back drive, they are usually referring to when the machine is off and the motor and is not powered. There shouldn’t be any back-drive while the motor holding the Z-axis lead screw is on, or the motor is undersized.
    This is still a problem though because you do not want to lose you position when your machine is off.
    Ball screws do have more of a tendency to back drive than ACME screw because of their efficiency (less friction) and usually having a high pitch. Even if an ACME screw and a ball screw have the same pitch (lead), the ACME will be less likely to back drive. ACME screw efficiency percent may be 20-60 while ball screws usually run from 50-80%. So for a ball screw there is less friction to keep it from turning due to the linear force.
    For ball screws with pitch less than 5 turns per inch, there will be a tendency to back drive with the weight of a normal router spindle and accessories, assuming that the linear bearings offer little friction. This is also the recommendation of Nook industries.
    Since you have a 5 (TPI) ball screw this is something to consider. You can use springs pistons etc. to make the assembly neutral weight or use a brake system. On one of my first designed I had this problem and made a brake that clamped the linear bearings. I just had to remember to lock it before cutting power and then cut power on and then unclasp before starting. After doing that I had little problems.
    On my other machine I used ACME screw with active suppression wedge nuts like the ones offer from dumpster.com. The lead screw was ½-10 2 start (5 TPI), and I had no problems with back drive.
    As a note, another solution is to build a simple contact plate. Apply an electrical charge (ground wire) to the spindle, and have small metal plate with the pos wire. Then you can create a simple macro to run to that plate and touch down with the tool. The circuit is complete when they touch (like a switch) and the Z-axis is always true. That way, even if you change the bit it will always have the same Z-height. With the driver software like Mach 3, this is very easy to do as it can detect switches.
    Sorry if I didn’t explain that very well but I hope this helps.
    Regards
    Brian
    WWW.CNCRouterSource.com
    35538
    Quote Originally Posted by lgalla View Post
    Single start screws will not backdrive, but multiple starts may. The higher the lead, the easier it will backdrive. Sorry, but I can't give you any real world experience on this.
Page 1 of 2 12
  1. acme leadscrew
    By drfoz in forum Commercial CNC Wood Routers
    Last Post: 08-05-2007, 05:57 AM
  2. how to straighten an acme leadscrew ?
    By belgrado in forum MetalWork Discussion
    Last Post: 09-14-2006, 05:36 PM
  3. Acme Leadscrew price
    By MrRage in forum Uncategorised MetalWorking Machines
    Last Post: 12-21-2005, 06:48 AM
  4. Leadscrew or Acme for Al. Router
    By js530 in forum DIY CNC Router Table Machines
    Last Post: 05-12-2005, 01:23 AM
  5. Acme leadscrew or Trapezoid leadscrew is better?
    By minicnc in forum DIY CNC Router Table Machines
    Last Post: 03-07-2005, 06:57 PM
