588,621 active members*
5,349 visitors online*
Results 1 to 3 of 3
    Low Cost Laser Engravers - List
    The following is a quick list of suppliers of low cost laser engravers. I don't know the best way to maintain a list here, but if people find other suppliers with websites, seems like this would be a good place to put them. This list is not an endorsement for any of the websites or suppliers, just what I have stumbled on or been lead to...
    Low Cost Laser Engravers:
    China Optronics
    STDK-4028
    http://www.chinaoptronics.com/engraver.htm
    HKXY
    custom made
    website..?
    Ink Express
    IE300 laser engraver
    http://www.iehk.net
    Jinan Hengxing Computer Equipment Manufacturing Co.
    Rabbit HX40A
    http://www.hxlaser.com/en/index.htm
    Red Sail: HF Laser
    3040B
    http://www.hflaser.com/jgdbj.html
    Wuhan Huahai Photoelectron Co.
    H40w Laser Engraving Machine
    http://www.huahailaser.com/eng/cpjj2.asp?id=173
    Feb 2008
    5
    Hi mate! This is an inquiry for buying a laser cutter for making a custom
    rubber/plastic/metal holder.
    This would be a Circular piece of rubber/metal/plastic (diameter 57mm). In the Center
    it has a rectangular cutout, that is approx. 35.5mm x 24 mm. The thickness of the rubber/metal/plastic should be about 2.5mm.
    Essentially I was going to buy a strip of 2.5mm thick rubber/metal/plastic and make
    cuts to end up with my final piece.
    The rubber/metal/plastic thickness is not much, and I am only looking at a 100 pcs a
    month, so its a low volume, low strength application.
    I was thinking that rubber or plastic could be cut by a low end laser. Would love to hear your recommendations .
    Thanks!
    Oct 2007
    240
    Answered in the other thread you posted this question in...
    Hi-TecDesigns.com -- Automotive Lighting Systems
