I have two 6061 alum. hubs that have 1/4" keyway grooves in them. I need to widen the groove to 5/16". Is there anyway easy way to do this using a drill press? Other suggestions for a DIY solution?
Hope this gives you some direction.
http://www.keyseaters.com/stock_custom_keyseating.htm
It is HIGHLY NOT RECOMMENDED, but you could use a single or 2 axis machine table to attempt it.
http://www.kbctools.com/can/Navigati...fm?PDFPage=453
www.integratedmechanical.ca
Minuteman broach kit? Opening a 1/4" keyway to 5/16" in aluminum shouldn't be too difficult.
Dick Z
DZASTR
Thanks everyone.
OK, so I learned about broaches and actually found a 5/16C broach and 1 3/8 bushing for about $50. Now it seems I need a $$$ machine to use it? What type of manual machine is available to push the broach? Sorry for the newbie-type question.
try an arbor press. shouldn't be too hard to track one down to use.
"you don't even need cnc if your handy with a torch"
Aluminum??
How about a hand file and a bench vise.
pix
Some of my best finds were in the trash....
