587,518 active members*
3,693 visitors online*
    Apr 2003
    307
    Drill Press or Mill/Drill?
    Well after moving my household across the country I am finally in one place again. What an ordeal!
    I sold my Chinese drill press since it had alot of runout and wear. So now I am looking to replace it.
    I wanted to get some opinions about how well mill/drills function as drill presses. Of course there ain't the hole in the table to run the bit through so I guess I would have to use a backer on the table.
    I need a basic manual mill also. My budget is about $600.
    Would I be better off getting an inexpensive drill press and a mini mill?
    Thanks,
    Chris
    Apr 2003
    307
    How about the 12 speed machines? Does anyone have one of those?
    I've been looking at the G0517 from Grizzley. I've seen others but that is the only one that has a 3MT taper and drawbar. Also, considering that it comes with a stand, vice and #1 & 2 MT adaptors, it seems to compete with the Speedway price. $525 vs $299.
    C
    Apr 2003
    550
    The Harbor Freight big red is the way to go on these. There is no real advantage to MT3 over MT2..
    There is a yahoo group on the big red and examples of adding fine feed.
    Garry
  1. Tap Drill Calculator Freeware
    By Rekd in forum News Announcements
    Last Post: 11-15-2011, 11:37 PM
  2. Removal of the drill press depth stop threaded rod
    By devinchi in forum Shopmaster/Shoptask
    Last Post: 03-14-2010, 03:10 PM
  3. Central Machinery Drill Press
    By JavaDog in forum Uncategorised MetalWorking Machines
    Last Post: 05-25-2005, 04:14 PM
  4. Drilling a perpendicular hole in drill rod material
    By ngr1 in forum MetalWork Discussion
    Last Post: 12-04-2004, 04:16 PM
  5. drill press x/y cross-slide
    By Dan S in forum Uncategorised MetalWorking Machines
    Last Post: 10-22-2004, 03:25 PM
