587,514 active members*
2,887 visitors online*
IndustryArena Forum > CNC Electronics > Phase Converters > Yasnac Lathe with VFD threading
Results 1 to 6 of 6
    Sep 2005
    92
    Is it possible to do threading with a VFD in the spindle, in a Lathe with Yasnac control? I have an Hitach J100 for 5HP, I belive it´s flux vector. The VFD does not have an index input nor A/B signal inputs.
    Thanks in advance.
    Jorge
    Dec 2003
    24220
    Most CNC spindles are VFD-like in Nature, some a little more sophisticated, but the general method is to use an encoder on the final spindle shaft and sync the Z axis by way of the encoder index pulse, with commercial controllers, the Z axis is then geared off of the encoder pulses, so even if the spindle speed varies slightly, the Z will track the correct feed.
    Obviously the controller requires the Threading option, also the encoder is used for CSF (Constant Surface Feed).
    Al.
    Albert E.
    Sep 2005
    92
    Ok, then the Yasnac is controling the threading function? And the flux vector VFD is only monitoring the RPM´s acording to the voltage command?
    It that how this works?
    Thanks,
    Jorge
    Dec 2003
    24220
    That is how the majority of commercial systems work, although some have more sophisticated spindles that others, it is easier to obtain precise control of the Z, rather that sync the spindle, in any case with an encoder on the main spindle, any variation in spindle gears etc such as backlash or variation in gearing etc, is not an issue.
    Al.
    Albert E.
    Sep 2005
    92
    AL,
    One last thing, do you know if this VFD can work with 1 Ph.?
    Thanks,
    Jorge
    Dec 2003
    24220
    According to Hitachi, the highest SJ100 usable on 1 phase is 3 hp model.
    Al.
    Albert E.
  1. Threading on a lathe.
    By Nic Scheepers in forum MetalWork Discussion
    Last Post: 07-28-2008, 08:32 PM
  2. Homing problem with a Hitachi HT-20 Lathe, Yasnac
    By Stoney372 in forum DNC Problems and Solutions
    Last Post: 10-02-2007, 01:39 PM
  3. CNC Lathe Threading
    By lathe guy in forum MetalWork Discussion
    Last Post: 03-19-2007, 11:21 AM
  4. threading on an HL-2 Lathe
    By Toddjones in forum Mastercam
    Last Post: 06-11-2005, 09:18 PM
  5. CNC Lathe Threading
    By DDM in forum Uncategorised MetalWorking Machines
    Last Post: 08-20-2004, 03:27 PM
