588,066 active members*
4,864 visitors online*
IndustryArena Forum > CAM Software > Mastercam > threading on an HL-2 Lathe
Results 1 to 6 of 6
    Sep 2004
    10
    Angry threading on an HL-2 Lathe
    Hi all, I'm very new to CNC and have plunged into it head first. A friend of mine is a CNC machinist however is experiance is limited in lathe work as it relates to the G Codes.
    We tried to perform a simple ID threading operation but I either get an Alarm or it does something weird.
    Here is the code!
    O0800
    G20
    (PROGRAM NAME - XXXXX DATE=DD-MM-YY - 16-09-04 TIME=HH:MM - 17:10 )
    (TOOL - 1 OFFSET - 1)
    (ID THREAD - MIN. .5 DIA. INSERT - NONE)
    G0 T0101
    G97 S200 M03
    G0 G54 X1.05 Z-2.0358 M8
    X1.2688
    G99 G32 Z-4. E.8
    G0 X1.05
    Z-2.0403
    X1.2852
    G32 Z-4. E.8
    G0 X1.05
    Z-2.0444
    X1.3
    G32 Z-4. E.8
    G0 X1.05
    Z-2.0444
    X1.3
    G32 Z-4. E.8
    G0 X1.05
    Z-2.0358
    M9
    G28 U0. W0. M05
    T0100
    M30
    My machine does not recognise G32 and I was advised to switch it to G92. It runs without an alarm using G92 however it does not perform the operation as it is suppost to. It seems to reverse the operation. My machinist said if I try running it I will crash the machine.
    I am very frustrated as I need to make parts with an ID threat.
    Any suggestions would be appreciated. He advised that there are no proper Post processors for HAAS lathe's and that I believe the said the closest POST processor is MFLAN.
    Todd!
    Mar 2003
    4826
    Check the Haas website for info
    http://www.haascnc.com/training/
    Look in the lathe workbook (the 9484 KB pdf file) on page 119 for instructions on G76 automatic multipass threading or page 140 for single pass G92 threading.
    I don't think your parameter "E" is valid. If it was meant to be the feedrate "F", you'll also have to check that your machine is running slow enough to be able to cut .8" per revolution, which is an extremely coarse thread. Most likely, you've got an erroronous value there.
    First you get good, then you get fast. Then grouchiness sets in.
    Jan 2004
    13
    try this
    try slowing down your spindle speed, right now you are running about 160IPM maybe to fast for the Haas
    try something under 150IPM
    Feb 2004
    7
    160 is capable on the haas... --but it is a HAAS ... never like haas very much.. (chair)
    www.datum1.com
    Datum 1 Engineering
    Ontario, CA
    909-923-8995
    Jul 2003
    13
    Well, if you are running a cracked version then your friend is correct, there isn't a HAAS specific lathe post on the installation cd so it is not easily obtained. However, if you really are a Mastercam customer, a quick call to your local reseller should get you what you need as there are several HAAS lathe posts available to them.
    Jul 2004
    93
    Simple Lathe Work Dose Not Need A Cam System, Wright It By Hand
    Like Hu Flung Dung Said It Can Be Done With A G76, Or A G92
    By Looking At Your Code It Will Crash G54 Z- Is A Bad Thing
    Here Goes A Simple Thread Cycle
    G97 S600 (SETS CONSTANT RPM)
    G99 (SETS UP IPR)
    G00 X.9 Z0.1 M08 (set Up A Clearance Move)
    G92 X1.0 Z-.4 F.05 (f= Pitch Or Lead Of Thread 1/20=.050 )
    X1.01
    X1.015
    X1.020 Etc Untill You Get The Proper Depth Of Thread
    Or A G 76 Works Good To
    G97 S600
    G99 (ipr)
    X.9 Z.1 M08
    G76 X=minor Z= Lenght D= Depth Of Thread U= 1st Pass Depth F= Feed
    G00 Z.1
    Double Check Me On U
    Hope This Helps
    Brad
    IF ITS NOT BROKE YOUR NOT TRYING HARD ENOUGH
    Ashes to ashes , dust to dust , If it wasnt for Harleys the fast lane would rust.
  1. Help me buy my first Mini Lathe
    By Highfly in forum Mini Lathe
    Last Post: 05-10-2005, 08:07 AM
  2. OneCNC XR Series Lathe CAD/CAM Released:
    By OneCNC in forum News Announcements
    Last Post: 03-07-2005, 11:20 PM
  3. Are ballscrews necessary for PRECISE work on a cnc lathe?
    By daytrader in forum Uncategorised MetalWorking Machines
    Last Post: 01-10-2005, 07:34 PM
  4. CNC Lathe Threading
    By DDM in forum Uncategorised MetalWorking Machines
    Last Post: 08-20-2004, 03:27 PM
  5. Taig lathe Threading and CNC questions
    By anoel in forum Mini Lathe
    Last Post: 01-12-2004, 10:43 PM
