587,171 active members*
3,163 visitors online*
Results 1 to 17 of 17
    Mar 2006
    50
    Problem with mach 3 or bobcad
    Although im new to using cad im not new to cnc programming but i have decided that nows the time to start using it due to needing the extra time although i have always enjoyed working the programs out myself.
    I have now started to use Bobcad but today i have hit a brick wall even though i have found the program very easy to use and to be honest i have very much enjoyed using it until now.
    I have drawn an elips of 50.4mm wide by 30mm high and hit the program button and genertaed the program with no problem what so ever until i have come to run it on mach 3
    The mach software shows that it has programed it with a few X and Y moves with no I or J following it so it wont run the program for some reason.
    Can anyone hlp with this and tell me why bobcad has done this or is it a problem with mach 3, bobcad,myself or a combination of all 3 that have got this simple program wrong?
    I would very much appreciate some help with this guys as now i have started using cad i have found myself really enjoying it but its getting me to the point where Im about to pull whats left of my hair out over this.
    Heres the program that bobcad generated for an inside elips of 50.4mm wide by 30mm high using a 5mm end mill with anti clockwise move and G41 offset.
    G00G90G21G54X0.Y0.
    T1M06 (5MM END MILL)
    G43H01Z1.
    G17G41P2.5
    G00X-34.7731Y-4.8343
    G01Z-2.F40
    G03X-48.9638I-8.2783J-40.4892F100
    G03X-58.0957Y-6.9776I6.8545J-33.1986F100
    G03X-51.3892I5.8674J-40.59F100
    G03X-63.5176Y-10.2804I9.3961J-21.5263F100
    X-66.9488Y-14.3285I9.0997J-11.191
    X-67.5655Y-22.3618I8.1912J-4.6692
    G03X-63.5324Y-27.7071I12.4868J7.1831F100
    G03X-66.9189Y-23.7233I8.967J3.4249F100
    G03X-58.1342Y-31.005I14.8048J18.1669F100
    X-51.3269Y-33.1657I13.5888J31.0081
    X-37.1362I8.2783J40.4892
    G03X-28.0043Y-31.0224I-6.8545J33.1986F100
    X-37.1362Y-33.5781
    G03X-34.7108I-5.8674J40.59F100
    X-28.0043Y-31.0224
    G03X-22.5824Y-27.7196I-9.3961J21.5263F100
    X-19.1905Y-23.74I-9.0997J11.191
    X-18.5327Y-22.3571
    G03X-19.1456Y-14.3389I-8.8054J3.3594F100
    Y-23.74
    G03X-18.5327Y-22.3571I-8.3454J4.8179F100
    X-19.1456Y-14.3389
    G03X-22.5677Y-10.2928I-12.5226J-7.1212F100
    X-27.9658Y-6.995I-14.8048J-18.167
    X-34.7731Y-4.8343I-13.5888J-31.0081
    G00Z1.
    G40
    G00G54X1.Y1.
    G54X0.Y0.
    M30
    elmor fudd,
    Unfortunately, I must tell you that this NC code is no good. I will show you a Vericut verification video of your code in my next post.
    And the looser is....
    Elmer,
    Here is the Vericut verification video of your code:
    [ame="http://www.youtube.com/watch?v=KOReKOyR1cE"]YouTube - cnczone ellipse part[/ame]
    You can plainly see that this NC code is your problem.
    I have attached the txt I actually ran through the Vericut processor:
    Attached Files Attached Files
    Mar 2006
    50
    Quote Originally Posted by Mike Stevenson View Post
    Elmer,
    Thanks for that mate but i know its no good hence why i asked the question about bobcad comming up with that program for an elips at the stated size in my post because thats what it generated and with me being new to cad i wasnt sure if it was me thats done something wrong or if their was a glitch in the bobcad sofware?
    Now you know that the bobcad is messing you up, not MACH3.
    Jul 2003
    1220
    Here is the code for a ellipse of 50.4mm wide by 30mm high with left comp. that V20 generated. I had no problems. (No lead in or exit)
    G00 X24.5659 Y-3.3575
    G01 X24.5659 Y-3.3575 Z0. F50
    G41 G03 X23.9524 Y4.6603 I-8.7883 J3.3599 F400
    G03 X20.5238 Y8.7066 I-12.5229 J-7.1355
    G03 X15.1148 Y12.0047 I-14.8224 J-18.2247
    G03 X8.2937 Y14.1656 I-13.6132 J-31.1251
    G03 X-5.9257 Y14.5781 I-8.2951 J-40.6517
    G03 X-8.356 Y14.1528 I5.8791 J-40.7506
    G03 X-15.0761 Y12.0222 I6.8651 J-33.3164
    G03 X-20.509 Y8.7191 I9.4029 J-21.585
    G03 X-23.9468 Y4.6706 I9.0935 J-11.2057
    G03 X-24.564 Y-3.3626 I8.1735 J-4.6683
    G03 X-23.9166 Y-4.7227 I8.951 J3.4263
    G03 X-20.5239 Y-8.7065 I12.4869 J7.1976
    G03 X-15.1148 Y-12.0047 I14.8225 J18.2246
    G03 X-8.2937 Y-14.1656 I13.6132 J31.1251
    G03 X5.9257 Y-14.5781 I8.2951 J40.6517
    G03 X8.356 Y-14.1528 I-5.8791 J40.7506
    G03 X15.0761 Y-12.0222 I-6.8651 J33.3164
    G03 X20.509 Y-8.7191 I-9.4029 J21.585
    G03 X23.9073 Y-4.7392 I-9.0935 J11.2057
    G40 G03 X24.5659 Y-3.3575 I-8.3284 J4.8175
    G00 X24.5659 Y-3.3575 Z10.
    Kiwi,
    G41 on a G03 move? Wow.
    Edit: I am being told this ellipse file is no problem with older versions of BC.
    Jul 2003
    1220
    Red face
    ...G41 on a G03 move? Wow.
    You're right Mike, should have had a straight path to enable compensation.
    Mar 2005
    368
    Here's v22 code but I was using a Fanuc6M post.
    Origin in center of ellipse.
    There are some guys in the Bobcad forum that are successfully using v22 for Mach.
    Maybe post a question there?
    Good luck,
    moldmker
    O100(TEST.NC)
    (FANUC POST)
    (JOB 1 CONTOUR)
    (TOOL #1 5.0000 ENDMILL ROUGH)
    G0G17G40G80G90G28 Z0
    T1M6
    S950M3
    M8
    G54
    G00X-13.0792Y7.4383
    G43Z2.54H1D11
    G01Z-12.7F57.961
    G41X-15.0761Y12.0222F96.602
    G03X-20.509Y8.7191I9.4029J-21.5851
    G03X-23.9468Y4.6706I9.0934J-11.2057
    G03X-24.564Y-3.3626I8.1735J-4.6683
    G03X-23.9166Y-4.7227I8.951J3.4263
    G03X-20.5239Y-8.7065I12.4869J7.1976
    G03X-15.1148Y-12.0047I14.8225J18.2246
    G03X-8.2937Y-14.1656I13.6131J31.1251
    G03X5.9257Y-14.5781I8.2951J40.6517
    G03X8.356Y-14.1528I-5.8791J40.7506
    G03X15.0761Y-12.0222I-6.8651J33.3164
    G03X20.509Y-8.7191I-9.4029J21.5851
    G03X23.9073Y-4.7392I-9.0934J11.2057
    G03X24.5659Y-3.3575I-8.3285J4.8176
    G03X23.9524Y4.6603I-8.7883J3.3599
    G03X20.5238Y8.7066I-12.5229J-7.1355
    G03X15.1148Y12.0047I-14.8224J-18.2247
    G03X8.2937Y14.1656I-13.6131J-31.1251
    G03X-5.9257Y14.5781I-8.2951J-40.6517
    G03X-8.356Y14.1528I5.8791J-40.7506
    G03X-15.0761Y12.0222I6.8651J-33.3164
    G40G01X-13.0792Y7.4383
    G00Z2.54
    M9
    M5
    G0G90G49Z0
    G28Z0
    M30
    The code is good.
    moldmker,
    You code is okay. I only had to add the G21 at the start.
    Kiwi,
    Your code is ok if you add the inch/mm code, plus tool change, initial move, rpm, and height offset at the begining and you delete the G41 on the G3 move as you can see in Pic1. Pic2 shows your code with the G41 left on the G3 line in a MACH3 machine simulation. Note the D flat on the right hand side.
    Attached Thumbnails Attached Thumbnails CNCZONE-KIWI WITHOUT G3 COMP.jpg   CNCZONE-KIWI WITH G3 COMP.jpg
    Jul 2003
    1220
    Your code is ok if you add the inch/mm code, plus tool change, initial move, rpm, and height offset at the begining........
    I was trying to help with the ellipse profile. I could see elmor had the other details sorted.
    Mar 2006
    50
    Kiwi,
    Your code is ok if you add the inch/mm code, plus tool change, initial move, rpm, and height offset at the begining and you delete the G41 on the G3 move as you can see in Pic1. Pic2 shows your code with the G41 left on the G3 line in a MACH3 machine simulation. Note the D flat on the left hand side.
    HA ha, youv hit upon the first problem i came across which promted me to re do the program.
    the first program i did was right for some of the elips but then as it got to the end it did a funny tuen and gave me a flat spot a little like you got but in a differant place.
    When i redid the program it gave me the above program i posted for some reason
    Now it seems to me that mach 3 doesnt like using the g41 or g42 offset codes or is this just me?
    I might have a go at programming the elips exact to compenstate for the tool in the size of the elips instead of using the offset values and see if it irons the glich out so fingers crossed
    Thanks for the help guys its much appreciated and if anyone else has any input that would be great to
    Mar 2005
    368
    Elmor,
    You can let the software offset the path, as well.
    In the Patterns window, when you use the No Offset L/R buttons the toolpath is generated directly on your geometry and the needed G41/G42 is added to G-code.
    If you use Offset R/L the toolpath is generated offset from your geometry by 1/2 cutter dia. plus any side allowance. This is a precompensated toolpath.
    However, depending on your post-processor, it may also add G41/G42 as a "wear offset"
    This can be changed with the MillPostEditor.
    Attached is shot of Patterns window.
    Good luck
    moldmker
    Mar 2006
    50
    Your not wrong mate
    pm on way
    Jay (elmer_fudd),
    Based on the IGS file you sent me this is my take on your part:
    O0001(BRACKET_DRAWING_DRAWING)
    G21
    G0G17G40G49G80G90
    (5.0 MM FLAT END MILL)
    T1M6
    G0G90X-39.878Y-10.503S2000M3
    G43H1Z100.M8
    Z10.
    G1Z-3.F1.8
    G41D21X-39.889Y-8.503F20.
    G3X-41.901Y-6.515R2.
    G1X-44.623Y-6.53
    G3X-50.873Y-7.295R38.52
    X-57.073Y-9.261R31.469
    X-61.923Y-12.21R21.052
    X-64.736Y-15.496R12.116
    X-64.767Y-22.446R6.97
    X-61.992Y-25.737R12.134
    X-57.125Y-28.716R21.146
    X-50.833Y-30.714R31.369
    X-35.227Y-30.705R38.819
    X-29.027Y-28.739R31.469
    X-24.177Y-25.79R21.052
    X-20.891Y-21.516R11.345
    X-21.317Y-15.585R6.954
    X-24.11Y-12.261R12.083
    X-28.975Y-9.285R21.134
    X-35.267Y-7.286R31.369
    X-41.901Y-6.515R38.961
    X-43.99Y-8.421R2.
    G1G40X-44.081Y-10.419
    G0Z100.
    X2.5Y2.5
    Z10.
    G1Z-3.
    G41D21Y-26.9
    X-13.469
    G3X-14.791Y-27.119R3.65
    X-16.45Y-28.37R3.875
    G1X-17.706Y-29.797
    X-18.943Y-30.948
    X-20.909Y-32.475
    X-22.998Y-33.821
    X-25.517Y-35.121
    X-28.139Y-36.203
    X-30.864Y-37.095
    G2X-36.182Y-38.239R42.073
    G1X-39.284Y-38.601
    X-42.403Y-38.75
    X-45.521Y-38.688
    X-48.625Y-38.416
    X-51.671Y-37.938
    G2X-55.45Y-37.033R40.487
    G1X-58.17Y-36.124
    X-60.671Y-35.082
    X-62.874Y-33.952
    X-64.974Y-32.628
    X-67.218Y-30.892
    X-68.689Y-29.49
    X-70.033Y-27.891
    X-71.161Y-26.201
    G2X-72.385Y-23.63R14.622
    G1X-72.877Y-21.927
    X-73.145Y-20.123
    G3X-73.226Y-17.74R43.298
    X-77.693Y-13.85R4.497
    G1X-87.9
    Y2.5
    G40X2.5
    G0Z100.M9
    M5
    G91G28Z0.
    G28Y0.
    M30
    Here's the Vericut video:
    [ame="http://www.youtube.com/watch?v=lPHYnljEbIQ"]YouTube - cnczone ellipse Michael style[/ame]
    Mar 2006
    50
    Now thats what its supposed to look like
    Thanks for your time with this guys and especially Mike.
    I have now come to the conclusion that Bobcad was a bad choice.
    I did the same program as above but it had glitches galore and didnt look smooth like Mike's program when loaded to mach 3 for some reason even though the program is more or less the same so Bobcad will be gone off my pc by the end of the day.
    I havent had chance to do a test cut with mike's to see what the finish is like but i have done a cut with my program from Bobcad and what i seen on the screen on mach 3 i got on the job so if Mike's program does the same it should come out fine.
    The one thing that is bugging me is that Bobcad state that they supply their software to NASA and other big companies but i would have thought that they must suffer the same glitches on drawings as i have done which i would have thought un acceptable to these types of companie or is it just a marketing ploy?
  1. Bobcat in the basement
    By metalbyter in forum Community Club House
    Last Post: 02-28-2008, 08:32 PM
  2. Anybody had this problem in Mach 3?
    By pointcloud in forum Mach Mill
    Last Post: 07-13-2007, 02:09 PM
  3. Bobcat V21
    By richrod in forum Spanish
    Last Post: 06-09-2007, 10:32 PM
  4. Jog problem with Mach 2
    By jtriggs in forum Mach Mill
    Last Post: 06-15-2006, 06:48 AM
  5. mach 2 problem
    By cncadmin in forum Mach Software (ArtSoft software)
    Last Post: 01-16-2005, 09:12 PM
