588,166 active members*
5,129 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Radius for hex-bolt pocket
    Jul 2008
    73
    I'm a newbie and am building some prototype parts of UHMW on my HAAS TM-1 mill.
    I have a pretty decent CAM system but I do not have much knowledge about mill tool selection.
    I am making a pocket in the UHMW into which a 1-1/8 nut will fit into.
    The corner radius of the nut is .010 the depth of the nut is at least 0.750 and I would like to be able to go deeper.
    I think I need an end-mill that is .020" diameter to finish this part of the job. The question I have is; where on earth can I buy one or is there a better way to do this job.
    Cheers,
    Bloefeld
    Dec 2004
    524
    Just cut the pocket with a 3/16 mill (or whatever). Then take the mill and starting on a line from the center to the corner, move outwards to make a recess that the corner will fit into. Do this for each corner.
    Unless this is decorative, there should be no need for the pocket to make contact with the corners.
    Alternatives are to chisel out the corners or use a rotary broach.
    Ken
    Kenneth Lerman
    55 Main Street
    Newtown, CT 06470
    Jan 2004
    3154
    I agree with lerman.
    But to answer your question, your tool supplier should have no trouble with that. My preferred brand is Ultratool.
    Mitsubishi makes some of the very best.
    An extended length .02 cutter will allow a .06 DOC.
    www.integratedmechanical.ca
    Nov 2004
    65
    Hex Broach
    I agree with lerman too. That seems to be the most popular solution when you need a polygon that size, just mill out the corner, it's really the flat you're after right? to hold the nut? If not, delivery on a 1.128 hex Slater hex broach is usually next day service. I guess that decision depends on how many pieces you're doing. Is your nut 1-1/8 thread or dimension?
  1. bolt circles
    By HIRAH in forum Calibration / Measurement
    Last Post: 03-04-2013, 05:57 PM
  2. Looing for an odd bolt
    By automizer in forum Community Club House
    Last Post: 06-29-2008, 06:20 PM
  3. RFQ: Aluminum Bolt Pin
    By warpedmephisto in forum Employment Opportunity
    Last Post: 08-07-2007, 08:22 PM
  4. Bolt Heads
    By justCNCit in forum Mechanical Calculations/Engineering Design
    Last Post: 07-16-2007, 03:11 AM
  5. Cheap Cam Bolt
    By Jimmy Southern in forum CNC Wood Router Project Log
    Last Post: 07-01-2005, 11:11 PM
