Originally Posted by
big_mak
Fergie,
What kind of cutter are you using? Solid or Inserts? If it's an insert tool you may have a tip not seated properly if it is what you describe, or your endmill may not be running 100% if it's solid. Just trying to rule everything out before you go and pull the machine apart!
