Is this a PC? Drive? What controller? what power supply?
Al.
Al.
Albert E.
It's a 3 axis cnc controller (not sure of the brand). It has a separate power supply that powers the gecko drivers and plugs into the control box. I'm getting a reading of about 32V from the power supply, doesn't matter if it's plugged in or not or turned on or off. thanks.
Here's a pic after I repaired it with the conductive epoxy and hooked it back up.
