Usually the biggest issue with interchanging is the ATC.
An ATC holds the tools by the flange groove and they are different there. Most machines will handle both tools if the correct pull stud is used.
IMO if you are already tooled for BT, I would stick with it.
You can get speeders with BT setup.
