This evening I removed one X axis rail and sanded the bottom edge as I did the top edge, then decided to hand sanded that whole side to remove most of the scale. No metal was harmed in the process. This will allow the paint to adhere better. I taped off the edges about 3/8" and spray painted the remainder with Rustoleum hammer finish silver. After the rail has been sanded and sprayed on the other side and cured I will wax the edges with pure carnuba wax to help retard rust and make the bearings run smoother. I'll do treat of the rails this way.
Sample photo below.
CarveOne
