Y axis lead screw mounting issues
Progress has been slow today. In the photo below you can see a bolt head in the middle of the rail behind the vertical box tube stiffener for the Z axis rail. There are five of these 5/16" bolts in the rail that attaches the 1" x 2" Y axis box tube stiffener with a nut on the rear of the box tube. The first thing that was needed was to change these so that the bolts are inserted from the rear and thread into the rail with no protrusion to allow the full 1" spacing between the rail and vertical box tube for the anti-backlash nut and lead screw.
After intently studying this for a full 0.5 picosecond or so, :withstupiI decided to just drill a clearance hole for a 3/8" x 1-1/4" bolt and thread the 5/16" holes for the 3/8" bolts. Conveniently, the 3/8" tap needs a 5/16" hole. Imagine that...... I don't have any of the bolts on hand though, so temporary pieces of 3/8" all-thread and nuts were installed from the rear of the gantry as I made each of the corrections to keep everything aligned. I'll pick up the bolts later this evening.
I also need to buy a hardened 7/8" hole saw to bore a hole through each end of the gantry for insertion of the lead screw. I'll probably need some extra clearance to get everything aligned and I don't want to have to enlarge these holes if I make them too small (like 5/8"). The hole saw has to pass through the 2" wide sides of the gantry end support box tube (0.120" wall thickness) and the 0.250" angle corner stiffener. I may end up milling away a small part of the corner stiffener if there is interference with the lead screw.
The alternative is to mount the lead screw on the rear of the gantry and mount the anti-backlash nut on the rear plate that I made yesterday. That requires making two new (and longer) bearing plates. I really want the lead screw closer to the center of mass of the Z axis assembly, and I really don't relish the idea of making two new bearing plates.
CarveOne
CarveOne
http://www.carveonecncwoodcraft.com
