588,548 active members*
5,774 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Open Source Controller Boards > TB6560HQ-Stepping Motor Driver IC 3.5amp
Page 2 of 14 123412
Results 21 to 40 of 272
  1. #21
    Jun 2003
    3312
    The other:
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
  2. #22
    364
    Very nice.
    I like the plugin type of the Naos. Looks like a G250/G540 style of setup.
    At what voltages and currents have you tested these chips?
    Did you also "intentionally" forgot the power-up and down sequence mentioned in the datasheet?
    Nice work.
    Regards,
    Luc.
    PS: I still should have a bunch of soldercup DB25's left over from my mini and mainframe computer service time ages ago, these can be mounted easily with the PCB between the pins.
    So you gave me a new idea for an easy configuration...
  3. #23
    Jun 2003
    3312
    Yes I did intentionally skip the "recommended" sequencing, kind of, Enable and reset are sequenced. Since there is no timing spec on the Vdd to VMA sequence, I decided to build it and see if there are any issues. So far no problems.
  4. #24
    Feb 2007
    4553
    Question
    Phil,
    Do you sell any of these as kits?
    How is the performance?
    Any Video?
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
  5. #25
    Jun 2003
    3312
    Kits, possibly in the future. Performance of the part is very good considering a monolythic IC. No video.
  6. #26
    Jul 2005
    27
    I will try with this IC.
    - Anyboby have the Eagle library of this chip to share?
    - I'm not electronic specialist, could any any one tell me how to calculate Rsense watts?
    _ Phil, I have good references of your schematics, do you have one to share with us?
    _____________________________________________
    Hare Krishna Hare Rama
  7. #27
    Feb 2007
    4553
    Question
    Phil,
    Do you have PCB's for sale for this?
    Jeff...
  8. #28
    Apr 2008
    57
    eagle lbr
    Attached Files Attached Files
  9. #29
    Jun 2003
    3312
    Quote Originally Posted by jalessi View Post
    Phil,
    Jeff...
    Sorry, not yet. I probably shouldn't have posted the picture.... I have several designs done and running, but won't have boards built in quantity till I get the last two designs "rung out". And I do this in my spare time when I'm in the mood......
  10. #30
    Apr 2008
    57
    Here PCB in Eagle
  11. #31
    Apr 2009
    21
    very nive thread !
    hi everybody,
    I just downloaded the eagle data from here. I will probably create my own layout starting with this one.
    Any known issues with the current board ?
    Biggest problem will be probably from where to get the chip (in old germany)
    real good job,
    regards
    Gerd
  12. #32
    Apr 2006
    169
  13. #33
    Apr 2008
    57
    Here pcb in Eagle, corect layout and TB6560 pinout
  14. #34
    Apr 2009
    21
    thanks for update the eagle, and for digi-key, I ordered already
  15. #35
    Apr 2009
    21
    applying power supply
    I have one question:
    In the data sheet p 28, I found "How to turn on the Power ...
    Turn on VDD. When the voltage has stabilized, turn on VMA/B.
    How is your design dealing with it ?
    kind regards
    Gerd
  16. #36
    Aug 2006
    9
    Here my SCH, LBR in Eagle
  17. #37
    Apr 2009
    21
    thanks celladon1.
    Yes this is a solution. Do you have any experience, can it really destroy the device without the relay ?
    Do the additional free wheeling diodes reduce thermal load ?
    regards
    Gerd
  18. #38
    Nov 2008
    4
    hi, here you can check russian design for TB6560 - http://www.purelogic.ru/PDF/Controller/PLC330.pdf
    also picture attached, it is full CNC 4x LPT controller.
  19. #39
    Apr 2006
    169
  20. #40
    Feb 2007
    4553
    Question Any PCB's available for this yet?
Page 2 of 14 123412
  1. THB6064H(4.5A)-Stepping Motor Driver IC 4.5amp
    By NASR1 in forum Open Source Controller Boards
    Last Post: 10-03-2014, 12:52 AM
  2. Stepping Motor Driver IC THB6064H
    By lihaijiang in forum Engraving Machines
    Last Post: 07-07-2009, 03:49 AM
  3. THB6064H stepping Motor Driver IC4.5A
    By lihaijiang in forum News Announcements
    Last Post: 06-22-2009, 03:29 AM
  4. Stepping Motor Driver
    By MR MOTION in forum Stepper Motors / Drives
    Last Post: 05-17-2009, 06:13 PM
  5. 80V 6A Micro stepping Motor driver
    By eded59 in forum Stepper Motors / Drives
    Last Post: 07-31-2007, 03:43 AM
