587,756 active members*
4,690 visitors online*
Results 1 to 7 of 7
    Jan 2009
    396
    need help id 8 wires
    Hi all I need help with identifying wires on 34H2160-62-8A nema 34 12Nm 8 wires (white, black, red, yellow, orange, green, brown, blue) from ms motor world.
    Jun 2003
    3312
    To find the phase pairs use an ohm meter and ring continuity. To find phase polarity, tape a tooth pick or some long stiff piece and tape it to the shaft to "magnify" the rotation. The take a D cell and connect a phase noting which way the step happens,clockwise or counterclockwise. Keep track so that you can determine whch lead connected to the + of the D cell makes it rotate the same direction. At the end you should be able to mark eah color pair belong to a phase, and which of the colors of the pair make it travel a certain direction. Thats enough to get you started so you can hook up a driver and determine the final pairing.
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
    May 2009
    54
    Nice ruler! :banana:
    Jan 2006
    58
    Take a look at this one, it could be match. You must translate colors from German.
    Attached Files Attached Files
    Jan 2009
    396
    Quote Originally Posted by pminmo View Post
    I don't quite understand that but I know blue n black is 1 coil, red n yellow is 1 coil, green and brown is 1 coil, orange n white is 1 coil but I don't know how they arranged inside.
    Jan 2009
    396
    ok I just got this from my supplier but now the problem is my Japanese isn't good, can someone translate it for me? see my attachment.
    Feb 2007
    4553
    Post
    15mgtar,
    I believe this is the wiring for your motor, you can double check it with a ohm meter as Phil has suggested.
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
  1. What wires should be shielded?
    By eat in forum CNC Machine Related Electronics
    Last Post: 07-23-2007, 05:16 PM
  2. What wires to use?
    By studysession in forum DIY CNC Router Table Machines
    Last Post: 02-21-2007, 08:02 PM
  3. Best way to keep wires out of the way
    By CuttersCov in forum DIY CNC Router Table Machines
    Last Post: 11-03-2006, 03:40 AM
  4. Lead Wires?
    By aggie_67 in forum Stepper Motors / Drives
    Last Post: 06-06-2006, 03:02 AM
  5. DIY shielded wires
    By HogDog in forum CNC Machine Related Electronics
    Last Post: 04-14-2006, 01:02 AM
