tm1p spindle air leak
i noticed a small air leak in the set screw on the side of the spindle last week and it has seemed to progressively get worse,and tonight i notice air leaking around the spindle.
i did a post search and couldnt find any info other than it should cut off shortly after spindle stops (which it doesnt)
seem to notice some potential maintenance issues just about everyday now.
anyone have anysuggestions whether i should fix it or leave it alone?
i also have several toolholders from various sources that some come out of the spindle like you are hitting the top with a hammer when you press the tool release button and others you cant feel them disengage.
are these issues related and are the belleville washers going to be the first place i start looking?
thank you in advance.
2007 Haas TMP-1 Microscribe MX-5 Mastercam X4 Mill Level 3 Surfaces,Solids Seagate 2 tb hard drive AMD 64x2 8gig ram windows ultimate 7 64bit Geoforce 8800 GTX
