![Quote](images/misc/quote_icon.png)
Originally Posted by
RB Precision
..... also I bought the high flow coolant pump and it trips the breaker in the cabinet every time I turn on the coolant. Im wondering if I need to take out the factory fuse and replace it with the one that came with the pump? Any info much appreciated.
I cannot help with the noise but this "factory fuse" caught my eye.
Is this a circuit breaker that plugs into the board in place of the original one?
What is the current rating on this one.
The reason I ask is that we bought a replacement high flow pump for one of our machines, and it constantly tripped the breaker. The motor is a different make than on all our other pumps and I suspected it was the motor was pulling a larger starting surge and that was tripping the breaker. We repaired the old pump for the machine and put it back in use....no more breaker tripping.
It seems maybe I am correct, it is the motor on the newer pumps, and now Haas supplies a higher rated breaker.
