588,662 active members*
5,075 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Cheap 1500W Chinese spindle, experiences?
Page 19 of 68 9171819202129
Results 361 to 380 of 1344
  1. #361
    Feb 2008
    154
    A quick test run of my 1.5kw air cooled spindle and the XIN YE ELECTRIC - YP-C1D5-2G VFD
    [ame="http://www.youtube.com/watch?v=eIgIbsv85qw"]YouTube - 1.5kw Air cooled Spindle[/ame]
  2. #362
    Apr 2006
    1016
    (nuts)(nuts)
    Quote Originally Posted by Hirudin View Post
    Are you saying there is a 150% markup from the Chinese suppliers? So the 2.2 kW spindle I bought for ~$275 only costs Chai $110? So, presumably it also costs HomeShopCNC the same amount. So when HomeShopCNC charges $875 for the same thing it's because of a 700% markup?
    keiling KL-2200ATC CNC Spindle with ATC: $3199usd
    same unit 2200atc from same manufacture in china 2100USD.
    and there stil making money, @ $2100
    Cutt out the middle men ... and you will save,,,
    HomeShopCNC does not buy one spindle at a time they buy in smaller lots from 3 party.... then sell to you there lots of mark up ...im not say keiling or HomeShopCNC.... make 150% these units dont cost that much to make in china labour is dirt cheap there.
    Dont know where you get 700% but it just hows you.. there are to many middle men... febay etc making a good mark up.... its easy money...
    cheaper will alwas have lower mark up, but the 3.3kw to 7.5 kw units have the more or less the same core... just larger...
    a little bigger motor etc larger bearings... larger vfd etc the labour cost to assemble is not much more to build.
    how much do think chai is make per unit... 20 bucks....
    i dont think so....lol
  3. #363
    Feb 2008
    154
    I went through the settings on my XIN YE ELECTRIC - YP-C1D5-2G against the ones that Scott listed from the partially translated manual.
    My concern is the report that setting the minimum frequency less than 100Hz won't allow the internal fan in the spindle to start which burns out the spindle.
    I thought it might be the P0008 setting, but the numbers don't make sense (it's currently set to 002.45).
    Here are my current settings (in blue):
    P0000: Running ways (0: Board Control; 1: outside control)00000
    P0001: Run Way (0: Board Run; 1: Expanding Terminal; 3: COM)00000
    P0002: Stop way (0:Speed-down; 1:Free; 2:Brake )00000
    P0003:The Max.Frequency(For example: If you want to run 60.34Hz, you can input 60.34)60.00
    P0004:The rated Voltage of the motor(Set according to the motor)0220.0
    P0005:The rated Curency(set according to the motor)0006.5
    P0006:The Permitable Over load parameter(0-150%)00140
    P0007:The Permitable over load time(1-90Second)00050
    P0008:The Min.frequeny limit(0-350)002.45
    P0009:The Min. Voltage limit(0-350)35.0
    P0010:Voltage setting(100-380)220.0
    P0011:Parameter Lock(0: changeable; 1: Unchangeable)00000
    P0058: The rated Frequency(set according to the motor. 50-320Hz is recommended) 00300.00
    P0056: The power of the motor spindle(0.8kw,1.5kw,2.2kw and so on)0001.5
    P0054: The limited Frequency of the motor spindle(60Hz)400.00
    I've only run my spindle for a short burst in the video in my previous post, but now I am a little hesitant in starting it up again until there is some confirmation on the correct VFD settings.
  4. #364
    Feb 2008
    154
    Here is a scanned copy of the Chinese manual pages 16-21, that details the code settings of the VFD.
    If anyone is able to translate any of it, it would be greatly appreciated.
    Attached Files Attached Files
  5. #365
    Jan 2008
    3
    My girlfriend translated for me and it seems right like you goot it.
    P0008:The Min.frequeny limit(0-350)002.45.
    is for the lowest frequenz to allow.
    try copy and paste from your PDF in to googletranslate or something
    works for me.
  6. #366
    Nov 2003
    104
    I am thinking of buying one of these, but I am limited to 110 volts. I currently have Hitachi lm100 1/2 hp vfd that runs off of 110vac, but that needs 10 amps in and only supplies 2.6 amp out. I have found a vendor in the states that has 3hp (2.2kw) vfd that runs off 110vac and outputs 10 amps. I know I can't cheat ohms law, but just want to double check. If this vfd has an output of 220v 10 amps, the input is 110vac...will I need a 40 amp line to make this work?
    http://www.lightobject.com/22KW-110V...ndle-P379.aspx
  7. #367
    Apr 2006
    1016
    spindle specs
    for those people which have purchased you spindles...
    i have this question for you... i see a lot of spindle advertisted as 380v 2.2kw
    my question is do the 380v units work on 220V power?
    or have most people not paided attention to this... or Should we just stayaway from 380 v units cus there trouble ...I would like to get some
    people to post there experiance and perhaps tell us what the spec on there unit was regard the voltage?
  8. #368
    Feb 2008
    154
    Here is a partial translation of the P code table from the manual. maybe P0055 is the one to set to prevent spindle burn out?
  9. #369
    May 2006
    309
    Quote Originally Posted by tootalew View Post
    With 2.2kw and 110V you will need minimum 20 Amp line to be safe.
  10. #370
    Oct 2005
    81
    John,
    Thanks for the translated P table. P0055 is worth a try. How did you do the translation??
    Scott
  11. #371
    Nov 2003
    104
    one more question...
    The air cooled spindles...is this air cooling like a vw (old) beetle or do you need to connect it to a compressed air line?
  12. #372
    Feb 2008
    154
    There are some people at work who do Chinese. I'm waiting on one other to do a translation to compare the two.
  13. #373
    Feb 2008
    154
    No. The spindle has an internal fan that does the cooling, so you just connect the three power wires (+ an earth wire).
  14. #374
    Jul 2006
    1256
    I don't like to chime in when I do not know for sure what I am talking about.
    I think you cannot get 220V3ph from 110V in.You must have 220V in???
    Larger spindles from China are 380V3phase.This is OK in Canada with Industrial voltage of 575V 3 Ph or US with 460V as a step down transformer is cheap.
    If running a home shop probably the largest spindle you can use is a 2.2KW 220V/3Phase.
    From the questions asked,a qualifyed electritian is required if you do not want to smoke the spindle or VFD.Suddenly your $300.00 spindle may cost over a grand.Qualifyed electritians are very busy as they are few.They can charge $50 to100/Hr for their services.
    Be careful
    L GALILEO THE EPOXY SURFACE PLATE IS FLAT
  15. #375
    Nov 2003
    104
    Lgaiia,
    Did you check out the link I provided? Here it is again.
    http://www.lightobject.com/Variable-...e-VFD-C44.aspx
    I also emailed them and they state they also have 110vac VFDs in 3 kw
    Keep up the good work on the epoxy/granite machine base thread. I have followed it from the beginning. I am currently building a gang lathe using a granite surface plate as the base.
    I believe it was the EG thread that inspired the surface plate. It is long term project..as time and money permit.
  16. #376
    Apr 2006
    1016
    Quote Originally Posted by lgalla View Post
    Be careful
    try this if you need 3 phase Its called a rotary phase converter, there lots of diy stuff and info out there or vfd option
    ....http://www.nojolt.com/how-to-build-a...onverter.shtml
    or this
    http://www.ronkelectrical.com/rotocon.html
  17. #377
    Sep 2009
    96
    Do you think the 1.5KW would machine aluminum ok? Or do you think it would require something more powerful?
  18. #378
    Apr 2009
    78
    Quote Originally Posted by eloid View Post
    or this
    I don't believe that the rotary phase converter would allow you to vary your speed as it would only put out the same frequency as input which would be 50 or 60 cycle. The spindles need 400 HZ or 400 cycles/second for max speed.
    A VFD, on the other hand, converts single phase to three phase plus varies the frequency for speed control.
  19. #379
    Mar 2009
    624
    Quote Originally Posted by scotta View Post
    I wired up the VFD after receiving the instructions. Good news is that the
    VFD runs (I have connected it to my lathe motor which I am using a
    Bonfiglioli VFD on normally). The bad news is that there was a bang out of
    the drive on first power up! And now sparking when the drive is turned on
    each time.
    I took the liberty to open the drive up and I found that one of the
    capacitors has blown the side out.
    No sign of the SGA and SGB RS485 terminals to be found anywhere either.....
    Hi Scotta,
    I,ve just recieved my vfd & spindle from Chai and it,s done exactly the same as yours. Flash bang on startup but still works and as blown exactly the same chip in the same place?
    I,ve not got intouch with chai yet as it`s only just happened,but just wondered how you have gone on regards your problem and if you got intouch with chai what was the out come?
    Like you i wonder why it`s happened and whether it,s worth sending back to china, which wont be cheap from UK or just try and replace the chip?
    All in all not a good start but i,ve dealt with Chai a few times now and always been treat with great respect and 1st class service, which i,m sure wil be the case this time?
    Cheers,
  20. #380
    Jul 2006
    1256
    Some confusion here.If you buy a 220V3Ph spindle and VFD you must have a feed of 220V single or 3Ph.If you have a 3KW spindle a 110V,VFD is usless.A VDF cannot up the rated Voltage.You must buy a spindle by the voltage you have in your shop.
    These spindles in general are 8,000 RPM to 24,00RPM and called milling spindles.To mill mild steel with a 3/8 end mill the RPM is 1067RPM.One zone member purchased a 50,000RPM spindle,These are only useful as circuit board routers.
    I feel sorry for Chai as he has bent over backwards to make people happy.From the posts here,Spindle smoking is probably from lack of information or knowledge from the users.Perhaps contacting some famous CNC Zoners such as Geof or Al the man could give some concrete answers.
    Confucious say too good to be true:Too good to be true.
    Larry
  1. Cheap and Simple ATC for Chinese Spindle
    By bogan in forum Spindles / VFD
    Last Post: 07-27-2018, 05:42 AM
  2. Chinese Spindle Experiences
    By analogman in forum DIY CNC Router Table Machines
    Last Post: 03-29-2013, 02:02 AM
  3. Cheap chinese spindle modifications - Generic
    By speedydumpster in forum Benchtop Machines
    Last Post: 03-28-2013, 04:28 PM
  4. Porter Cable or Cheap Chinese Spindle?
    By 777funk in forum DIY CNC Router Table Machines
    Last Post: 01-21-2011, 08:15 PM
  5. Connecting a hitachi VFD to a cheap Chinese Spindle
    By zigmart in forum DIY CNC Router Table Machines
    Last Post: 11-26-2010, 07:35 PM
