587,482 active members*
3,470 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > 80 VDC, 15 AMP, Powersupply
Results 1 to 7 of 7
    Dec 2009
    41
    I am a newbie and I need help building/finding a power supply capable of 80 to 90 VDC and upto 20 amps. I looked around on here and found a couple of tidbits on the subject, but I am still not clear. Does anybody have any info that will help me understand this?
    Thanks for the help!
    Dec 2003
    24220
    The hardest part my be finding a 1.5 ~1.8kva transformer.
    There was a guy on ebay that made them up toroidal's to order, Antek, but he does not seem to show up in a search.
    If you can find the transformer, the rest is easy and there are plenty of previous links here to building your own.
    Al.
    Albert E.
    Dec 2009
    41
    What did of transformer should I be looking for? I am an HVAC guy so traditional transformers are all I know. I don't know anything about a toroidal.
    Dec 2003
    24220
    Laminated or toroidal will work, it is just that toroidal are easy to modify by adding or reducing windings if necessary or adding an auxiliary winding on for low voltage source etc.
    If you google DC power supplies and toroidal transformer it should bring up plenty.
    I see that Antek has a web site now, so it may be worth an email to check on what he can do for you.
    Al.
    Albert E.
    Dec 2009
    41
    Thanks for all the info!
    Dec 2003
    24220
    BTW for 80vdc you will need 56acv secondary and 63vac for 90vdc.
    So 1.5kva will be fine.
    Al.
    Albert E.
    Feb 2007
    4553
    Post
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
  1. SX3 Powersupply gone bad???
    By idtkid in forum Syil Products
    Last Post: 06-11-2009, 11:48 PM
  2. Powersupply
    By nenetwork in forum CNC Machine Related Electronics
    Last Post: 04-06-2009, 03:58 AM
  3. Powersupply
    By CR250Greg in forum CNC Machine Related Electronics
    Last Post: 07-20-2007, 08:17 PM
  4. can I use this powersupply?
    By jimluu in forum CNC Machine Related Electronics
    Last Post: 04-30-2007, 04:05 AM
  5. My Powersupply
    By barkster in forum CNC Machine Related Electronics
    Last Post: 04-12-2004, 04:27 PM
