588,597 active members*
11,309 visitors online*
Page 5 of 10 34567
Results 81 to 100 of 191
  1. #81
    Apr 2006
    1016
    echain
    that echain (x, y) looks to small and filmsy for the unit and build.... the damp weather is starting to rust your unpainted parts ie wheel hubs..( time for paint and cnc noise)....other wise looks nice.
  2. #82
    Feb 2010
    202
    Smile
    first test
    [ame="http://www.youtube.com/watch?v=qI02q-kaMrk"]YouTube- 5 axis cnc - test 1[/ame]
  3. #83
    Oct 2009
    272
    Egor, come quickly....It's alive.
    Outstanding! Congratulations! Nice job!
    What more can be said.
    Randy,
    I may not be good....
    But I am S L O W!!
  4. #84
    At this point, with those dimensions, it would be nice to have a camera near the spindle the to see what the tool is doing without the need of a binocular...
  5. #85
    Feb 2010
    331
    looks like it works to me.
    next step a car carved from a single aluminum billet!
  6. #86
    Apr 2008
    211
    WOW!!
    Were not worthy!
    Were not worthy!
    I love it!in the driveway to boot.
    In such a short time and battling the elements as well.
    I tip my hat to you!Congratulations
    YOU,are the man.
  7. #87
    Apr 2006
    1016
    mach screen sets
    how much work was require with mach screen set for the additional other axis
    dro etc...or is this download able 5 axis of mach setup?
  8. #88
    Aug 2008
    110
    Wow what a machine
  9. #89
    Oct 2005
    2392
    Great to see it moving!!
    I still think you should have designed in more reach to do a greater undercut.
  10. #90
    Aug 2007
    62
    Red face
    Congratulations!!!
  11. #91
    Feb 2005
    130
    do you have nice 5axis gcode to test?
  12. #92
    Mar 2008
    177
    Talking
    Awsome machine! Congrats:cheers:
    Gene Crain
    www.plantasymaderas.com
    www.cnczacatitos.weebly.com
  13. #93
    Feb 2010
    3447
    WOW where do you live?! This is epic!!
  14. #94
    Aug 2009
    392
    Quote Originally Posted by diyengineer View Post
    Says Poland on his profile.
  15. #95
    Feb 2010
    3447
    This is probably a stupid question, because i know the possibilities are endless, but what does he mainly plan on milling with this monster? Is he going to buy blocks of metal the size of small cars and mill them lol. I want to know what he plans on doing with this beast on a regular basis.
  16. #96
    Dec 2009
    122
    I gather that is being made for sale, if I remember an earlier part of the thread.
    01000111011011110111010000100000010011010110100101 1000110110010100111111
    Maxx
  17. #97
    Feb 2010
    202
    Smile
    machine will used for milling forms fairings for trucks
    I build this for customer. I wanted to show that in terms of the amateur can build a machine for industry
  18. #98
    Feb 2005
    130
    We live in Poland (EU)
    View Larger Map
    Poland = Polska
    View Larger Map
    View Larger Map
    Quote Originally Posted by markcomp77
    its for surface treatment of mold (mould) for thermo forming machine (moulding machine)
    He is not going to mill metal (hard materials)
    Quote Originally Posted by MyCattMaxx
    it has been built on request (order)...
  19. #99
    Apr 2006
    3498
    Great work you have done..
    I just want to know about the stepper motors and drivers...Yours 28NM stepper Motors are beefy i think you also used one 58NM motor too.. I am building 2000mm X 2000mm X 300mm Gantry Router that will have a capability to cut 150mm STEEL PLATE...
    I need your help as you have done a major part in your machine..CAn you tell me please about the stepper Motor supplier and from where you got the stepper Controller Cards?
    and also kindly tell me Why you not used Servo?
    I will be thankful for your reply.
    http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
    http://my-diysolarwind.blogspot.com/
  20. #100
    Feb 2005
    130
    Quote Originally Posted by Khalid
    on X1,X2 and Y axis exist 28Nm
    on Z,A and C axist 50Nm motors
    It is difficult to found 58Nm on market... even 50Nm is not cheap (28Nm is much cheaper)
    I am a supplier of motors, drivers and other modules of electronic (as a ready to use control cabinet)
    28Nm is 110mm size, 7.8A current
    50Nm is 130mm size, 7.8A current
    to control this motors, you need to use high voltage driver
    I use additional trafo - 230/180, so.. I use lower voltage
    but.. it is possible to use 230VAC powering
    I recommend you to search driver with 7,8A current and 230VAC powering
    and 28Nm stepper motors (or 30Nm)
    other elements of electronics - typical
    opto isolation for lpt (BOB)
    protection for AC powering - varistor, filters, fuses... isolation transformer (big)
    if you will use BIG toroid trafo - softstart is needed!
    Controller Cards - it is opto isolation for lpt (BOB) (my diy)
    I added extra LEDs and resistors - to have light effects ... and 24V controlling of drivers (like servo drive have)
    -cost
    -and simplicity of steppers (no need of encoder cables)
    look on needed torque on A and C axis... is really big
    gearbox solve the problem... but cost is HIGH (needed for servo and stepper motor)
    so...it was chosen timing belt as a gear to enlarge the torque (3x50Nm)
Page 5 of 10 34567
  1. 5aXis-USB-iso-BOB
    By Yachaan in forum Open Source Controller Boards
    Last Post: 09-20-2015, 05:48 PM
  2. Semi - DIY CNC Router / Mill Project Build (With photos)
    By rescueweasel in forum CNC Wood Router Project Log
    Last Post: 08-30-2014, 06:21 PM
  3. 5axis help
    By BOATDUDEGUY in forum Mach Software (ArtSoft software)
    Last Post: 02-24-2014, 08:08 PM
  4. My CNC build-up with video and photos + everything a beginner should know
    By dmoore in forum DIY CNC Router Table Machines
    Last Post: 02-07-2008, 02:53 AM
  5. 5axis Help
    By jybute in forum Haas Mills
    Last Post: 11-22-2006, 03:10 PM
