I'm about 80% done with my setup now. Here are some pics
Behind the lcd panel is basically a cabinet area where a small computer resides next to a 5 gallon water bottle. The bottle has pvc piped into it from the top where there is a drain for dealing with flood coolant. The top...where the taig resides is a homemade acrylic setup which is waterproof. It is housed inside the pine walls of the top. And then an 80/20 aluminum frame sits on the 4 inch height pine walls. It all sits on 4 heavy duty wheels/casters. It has a 1.5 gallon shopvac on the side where the hose connects to locline pipes. Can act as a blower or a vaccuum. The controller is geckodrive 540.
What's left is to build the enclosure front doors and install a pump for the flood stuff. Oh, also protect the wiring with tubing....and to drill some holes in the back to let the wires out. And to install some limit switches and a red kill switch. USB rubber keyboard...and maybe an area below to store end mills and stuff. I'm currently trying to get Solidcam for solidworks running on mach3. Something needs calibration because it is creating gcode that is telling the table to move way too far on the x axis.
