Today I ran a job that was about 3.5 hours long on my X4+. Everything worked great, I shut-down for about 15 minutes for a break then went out to setup a new part.
I turned on the computer, started Mach3 and then turned on my x4+ - no issues. I tried to home the machine - cnc mode selected -> offset screen -> ref all to home and ran into some strange behaviour.
The Z-Axis homed okay, but the Y-axis moved about 2/3's of the way to the limit switch and stopped. When this happened, Mach3 set a 0.0000 value for the Y-axis and placed the mill in manual mode?!? I tried again, and the Y-axis homed, but the X-axis stuttered its way there and required three retries. Interestingly the mill did not get switched to manual mode in each false home situation - about 20% of the time as it turns out. I am able to move all axes at will and without issue by using the keyboard commands / GCode - the problem appears to be localized to the homing function.
I moved the axes to random positions and tried to re-home with varying degrees of success. Sometimes Z would work, sometimes Z and Y would work - X always requires at least one so-called restart.
I rebooted the controller PC at least 3 times but it did not seem to make difference. I have not messed with my Mach3 profile and the speeds / feeds I was using today were well within the X4's capabilities. Has anybody else experienced this sort of thing? I am going to leave the machine turned off until the morning, and I will try it again...
thanks,
steve
