587,104 active members*
4,323 visitors online*
IndustryArena Forum > CAM Software > Mastercam > How To Cut This Solid's Surface
Results 1 to 7 of 7
    Jan 2006
    461
    I have a part that has a contoured top surface and 6 drilled holes. The holes are no problem, however the contour itself is giving me issues. I have never used the solid machining toolpaths with mastercam x3 and while I tried to research online through the many tutorials, I came up empty with this one. Would anyone like to offer their guidance on how to do this. Thank you very much.
    The iges with parasolid data is included in the attachments.
    Attached Files Attached Files
    Apr 2010
    If the part was made in Solidworks or something similar, export the part without the holes and import it in MasterCAM on a different layer. It will be much easier to program a surface without the holes.
    Jan 2006
    461
    Ok, I will see if I can get it tomorrow. Thx
    Jan 2006
    461
    Here is the updated without the holes. I am using the post for a Tormach
    Apr 2010
    I just programmed it real quick with MasterCAM. I used surface mill, flowline. Seemed to work fine for me.
    Jan 2006
    461
    Hey Wingnut, thx. I got it. Thank you very much.
    Apr 2010
    No problem.
  1. MX3 SURFACE TO SURFACE TRIM
    By 82rouled in forum Mastercam
    Last Post: 05-18-2009, 06:02 PM
  2. Surface to Surface Filleting and Trimming
    By cowpoke in forum Mastercam
    Last Post: 03-17-2009, 02:42 PM
  3. Mastercam X3 solid's help
    By chippah in forum Mastercam
    Last Post: 03-05-2009, 10:29 PM
  4. surface help
    By msn_jrd in forum Mastercam
    Last Post: 11-20-2008, 01:28 AM
  5. *.obj to surface in MX2?
    By tesart in forum Mastercam
    Last Post: 05-28-2008, 09:41 PM
