603,354 active members*
3,799 visitors online*
Results 1 to 5 of 5
    May 2009
    281
    start stop switch wiring
    any body know the pinouts for the start stop switch? I'm thinking of switching my machines to xp, unless things have changed you have to have a start stop switch to interrupt the run in xp.
    Jan 2007
    723
    It depends on what type of controller and card you have.
    http://www.glenspeymillworks.com Techno LC4896 - 2.2Kw Water Cooled Spindle | Moving Table Mill from Omis 3 CMM, 500Lb granite base | Epilog Legend 32 Laser Engraver
    May 2009
    281
    Pplug, you are absolutely right I use the pci 400 cards with the riser card on my 4 axis and w/o on my three axis,
    Jan 2007
    723
    if you had the regular LC control box I could help you. Although heres where I found out what pins are for the probe on the aux connector in my controller.... First I loaded the free probing software. Next, I went to the diagnostic section in the probe settings panel. I then proceeded to see where the probe was supposed to be connected by shorting ground to the pins. I think an e-stop can be wired in this way.
    Apr 2010
    Commandline switch to start and stop server:
    cerberus.exe /start starts ftp server
    cerberus.exe /stop stops ftp server
    Regards
    JMG
  1. need advice on start stop switch replacement on jet jmd-18pf
    By Jet user in forum Benchtop Machines
    Last Post: 02-20-2010, 09:47 PM
  2. Where to get relay and e-stop switch
    By forrest39 in forum Benchtop Machines
    Last Post: 10-14-2009, 04:39 PM
  3. E-Stop Switch
    By crocky in forum Automation Technology Products
    Last Post: 10-10-2008, 04:34 PM
  4. Emergency Stop Switch
    By BOBINETTE in forum Hobbycnc (Products)
    Last Post: 12-28-2007, 06:41 AM
  5. pminmo BOB and NC E-Stop switch
    By kiltjim in forum CNC Machine Related Electronics
    Last Post: 11-21-2007, 01:57 AM
