587,322 active members*
3,354 visitors online*
    Feb 2007
    54
    Ncnet lite Okuma 500l-g
    Ncnet says it is transmitting but we get no verification on the okuma....when we punch "Read" on the Okuma we get the message "RS232 not ready"
    Any help would be appreciated
    com channel: serial port
    port number:1
    baud rate: 2400(machine and PC)
    Jul 2004
    173
    Okuma
    Try punching from the machine first so you can verify you have a good file and known format.
    Greg Mercurio -Shop Floor Automations
    www.shopfloorautomations.com /619-461-4000
    Feb 2007
    54
    I haven't done serial communications since the 1990s, can you elaborate a little?
    We are using the correct file extension, .min
    Are you talking about what is actually in the NC file itself?
    How do I know if I am getting any coms at all?
    Sep 2007
    13
    wiring
    The machine will tell you if it thinks no wire is connected.
    It will do it by that alarm rs232 not ready.
    The computer will not say there is no plug, but the machine will.
    You are able to get on this forum, so I assume you are tech enough to plug in the cable.
    That means the setup info is wrong or the wire is not jumped right.
    You have some work ahead of you if you can not readily find these answers.
    If you are good at this stuff you will find it quickly.
    If not you should call a tech.
    The setup would be stop bits, handshaking, baud etc.,
    The wire jump deals with the actual wire in each plug connecting to the wire in the other end of the plug. They do not all go straight thru!!!
    Check in these 2 directions. (or call the previous post he left a #)
  1. Problem with NCnet Lite....
    By gearsoup in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-24-2011, 06:29 PM
  2. Ncnet Lite
    By katsbobo in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-28-2011, 11:24 PM
  3. ncnet lite
    By krustykrab in forum DNC Problems and Solutions
    Last Post: 02-10-2010, 08:15 AM
  4. NEED ALLEN BRADLEY 8400MP PARAMETERS FOR NCNet lite software
    By Msobalvarro in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-03-2009, 08:15 PM
  5. Okuma CNC OSP 500L-G
    By rajappa in forum Okuma
    Last Post: 06-03-2008, 11:36 AM
