587,687 active members*
3,614 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Mini Lathe > 7x14 mini lathe with electical short
Page 1 of 2 12
Results 1 to 20 of 31
    Jun 2007
    I used my lathe for the first time since last Fall and it has a short somewhere.
    It runs but if I touch it with my bare hands I get a mild shock.
    Is this a common problem?
    If so what causes it and what can I do about it?
    Dec 2003
    24220
    The machine is not grounded properly.
    check continuity from the lathe frame to the service ground at the supply socket.
    Al.
    Albert E.
    Jun 2007
    That's a good idea and I will check it when I get home.
    But if so I wonder how it became ungrounded just sitting on the bench?
    Dec 2003
    24220
    It has been shown here before that ROC electrical standards sometimes leave alot to be desired.
    Al.
    Albert E.
    Nov 2007
    616
    Lol, I didn't know ROC even had electrical standards. Still, I would think that they would be required to meet standards of the country to which they are being imported.
    Problem may not be in the lathe, but maybe something happened to your outlet or wiring.
    Daystar Development didn't build your house, did they?
    Mar 2008
    3655
    Quote Originally Posted by blades View Post
    I second Blades' suggestion to check the outlet first. Go to Home Depot, Lowes or even Harbor Freight and buy an outlet tester:
    http://acmehowto.com/howto/homemaint...outlettest.php
    BTW: Electrical conduction depends on skin resistance. That mild shock from touching with a dry hand could become quite serious if touched with a wet or sweaty hand--And DEADLY if there is also, say a bare foot touching ground.
    This problem needs IMMEDIATE attention before plugging in the lathe again.
    CR.
    http://crevicereamer.com
    Too many PMs. Email me to my name plus At A O L dot com.
    Dec 2003
    24220
    Very simple to test the ground path on the outlet, use a 60w~100w lamp and use a couple of jumper/test prods to go between hot side to ground pin, the lamp should light at full brilliance with 120v across it.
    Old electricians trick.
    Al.
    Albert E.
    Feb 2010
    They actually have very strict electrical standards. Easy to understand too. 1. If you build something that burns down your factory, you will be executed and your family persecuted. 2. All bets are off once it ships
    You can also check your outlet with a volt meter. If the outlet is right-side-up, HOT is on the left, NEUTRAL on the right, GROUND on bottom. HOT is also the slightly taller blade/slot. Volt meter to volts AC at a range over 120 (usually that is the 200 volt range, cheap meters it's often 2000 volt range).
    HOT to NEUTRAL = 110 to 120 VAC
    HOT to GROUND = 110 to 120 VAC
    NEUTRAL to GROUND = 0 VAC
    You must check all three, even for a ground problem. I wire with grounded metal outlet boxes, so I also verify HOT to the switch plate screw or the box itself = 120 VAC. This is the best test. In fact, I wouldn't have one of those plug in circuit checkers in my home/shop. I would through it at whoever put it there. Years back, I would recommend a xenon bulb tester if you couldn't afford a meter, but now you can get a decent meter at HF for under $5. Back-lit LED for under $10. A clamp meter for load balancing your circuits for $15. A very nice meter for $30. Al, hire a new electrician, your old one's a tight (_!_)
    WARNING: Consider all the connections HOT. Unlikely that ground will become hot at the outlet, unless miss-wired, but neutral passes current and can most certainly kill you. True, neutral ties to ground at the circuit breaker box, and normally has no potential in reference to ground, but get a hold of it while an appliance downstream passes the current to neutral, and it will make your day.
    Now, if we use a Chinese volt meter and all seems OK, is it really OK?
    Dec 2003
    24220
    Quote Originally Posted by knudsen View Post
    I seem to remember an issue in previous post where the ROC manuf had a 120v outlet on the machine using a male pins socket instead of female?? .
    Quote Originally Posted by rcr22b View Post
    What is the verdict?
    Al.
    Albert E.
    Feb 2010
    I surprised we don't frequently hear of people buying an imported gizmo at (fill in the blank) ____-mart, plugging it in and getting their socks zapped off or burning their house down. Probably our saving grace is plastic doesn't conduct electricity well.
    Unrelated, but still regulatory, I saw a thing on Energy Start the other day. Manufacturers claim compliance, add the sticker, and no one follows up on it or does any testing. At my last company, way too small to afford real UL testing, we just bought UL listed power cords and used those We came in under the radar and/or claimed prototype status so we didn't need to comply with much. When CE came out, we freaked out thinking we would loose 30% of our biz because if we couldn't comply, we couldn't ship to EU. After looking into it we found CE is self certification that doesn't mean squat. So we bought CE stickers
    Jan 2010
    100
    Best bet is one of the motor wires has frayed, and is now grounding out to the machine.
    Start with the switch face plate(pull it) and check the wires behind it so see if one of them has a fray or strand of wire touching the metal, then chase the wires down to the motor and check them out as well (pull the cap cover on the motor).
    Granted that the ground on your Home outlet ground may not be connected correctly and causing the problem (feed back if someone just used a neutral wire for the ground circuit instead of a dictated ground wire circuit), but the off/off switch on the machine is only amp over load rated to trip, and not a GFI device.
    Also, take a good look at the cap and it wires as well. The energized cap can put out some major voltage, and if allowed to ground out to the metal, will cook the cap in no time at all (read no joy finding a replacement cap since the US models are all larger than the one on the motor that fits under the cover).
    Dec 2003
    24220
    Quote Originally Posted by Dano523 View Post
    It is possible, but if the machine is properly grounded then it should have either blown free or tripped the breaker.
    With AC you do not need a direct resistive connection to pass current to ground, if the machine is not grounded and you are standing on a damp floor etc, the path can be capacitive or inductive, very small current but enough to feel a slight tingle.
    Especially if not used since last fall, dampness in the motor and other wiring could be the cause of leakage.
    Al.
    Albert E.
    Feb 2010
    Good points, Al, on the AC coupling to chassis.
    In my collection of old tools are 5 or 6 metal housed power tools, mostly drills. Man, I hate testing those before buying! I always rewire or at least inspect them before running them at home.
    Nov 2007
    616
    ........ HOT is also the slightly taller blade/slot.
    Lol!!! :rainfro:
    I was just mulling over that very question! Kind of like putting the drunk in charge of the bar! :rainfro:
    Are you sure about the taller slot being hot?? I thought it was the shorter one. I didn't have a spare outlet laying around to check, but I could have sworn the shorter slot was hot.
    Mar 2008
    3655
    Good catch Blades! And you are correct. It IS the short slot that is the hot one.
    CR.
    Dec 2003
    24220
    It is like the outlets that are installed with the ground pin at the top instead of the bottom.
    The reasoning is if the weight of the cord etc pulls the plug down from the outlet, the ground remains in to the last!.
    I have seen many wired the reverse!
    Al.
    Albert E.
    Mar 2008
    3655
    Al.
    If that is the reasoning behind that silly electrical code, then it's specious. With the long ground pin on the bottom, the plug is much more solid in the outlet and actually RESISTS pull out. With the ground pin on the bottom, the ground pin will be the last pin out.
    With the ground pin on the top, not only is the plug more likely to pull down and come out, but the HOT pin will be the last to remain in.
    You can verify this yourself with a 3 prong plug, an outlet and about 10 seconds.
    I prefer the ground on the bottom.
    CR.
    Dec 2003
    24220
    Quote Originally Posted by Crevice Reamer View Post
    CR.
    This was my whole point.
    I guess I must have indicated the reverse somehow??
    The customary way to wire an outlet is with the ground pin at the bottom.
    Al.
    Albert E.
    Feb 2010
    OK, I gotta go rewire my outdoor extension cord. I chop the end off about once a year. Once with a circular saw, many times with hedge trimmers, never with the electric mower LOL.
    Wen I was young, I spent most of my money on fast women, slow horses, and cheap booze. The rest of it I just wasted.
    Feb 2010
    Yup, I checked, Neutral is the big one. I forgot to mention it can be a sideways "T" (I think 20A only?). I got the cord right. I'm blaming fatigue. No sleep last night, two hours the night before, don't remember the night before that, but Saturday was an 18 hour prescribed drug coma.
    Thanks for being gentle. I'm a basket case. I'm sofa king we tar Ted.
Page 1 of 2 12
  1. Replies: 124
    Last Post: 08-03-2012, 08:30 AM
  2. Micro-Mark Microlux 7x14 Mini Lathe
    By Jaime128 in forum Mini Lathe
    Last Post: 06-02-2010, 04:22 AM
  3. 7x14 Mini Lathe CNC Kit
    By Jason23 in forum Mini Lathe
    Last Post: 03-15-2010, 03:34 AM
  4. Microlux 7x14 Mini Lathe Conversion
    By TacPyro in forum Mini Lathe
    Last Post: 02-13-2009, 09:44 PM
  5. Retrofit 7x14 lathe 2axes with Theading.
    By rruybal in forum Vertical Mill, Lathe Project Log
    Last Post: 01-21-2008, 06:30 AM
