603,839 active members*
4,382 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Trouble with homemade CNC machine glitching
Results 1 to 6 of 6
    Sep 2009
    9
    I recently finished constructing a cnc with uses the hobby cnc 205oz motors and their pro chopper board. Using mach 3 and mastercam to program it. The machine with randomly freak out, jerking back and forth a short distance on one axs and not not moving correctly for a short time and then the program continues. It is very intermittent and this code has been verified by other machines and the mach 3 tool paths. I have a nice computer running it with a PCI parallel port card. XP Pro in Standard PC mode. Interesting to note I duabooted EMC2 and the test showed a latency value 100x more then recommended. Not really over that learning curve yet. My other concern is it might be noise. I connect the motors with cables, connect all the commons to the foil wire shield (in pictures). I did this to prevent noise but it may not be the correct way? The motors are running at 2.5a. Also the Z and Y axis wiring is ran together through a wire guide in close proximity for 4 ft+, noise an issue?
    So I figure its either:
    software parallel port problem
    noise
    Attached pictures, what do you guys think?
    Attached Thumbnails Attached Thumbnails P1010561.jpg   P1010564.jpg   P1010562.jpg   P1010557.jpg
    Oct 2006
    976
    Hello,
    Have you done any motor tuning with this machine and axis calibration?
    Regards,
    Wes
    Oct 2005
    1237
    Did you connect the cable shield foil at both ends? This is BAD and will cause ground loop interference. Only one end gets grounded and the other end floats.
    May 2010
    13
    Quote Originally Posted by MrWild View Post
    This is true if just using it as shielding, but from the wiring diagrams for the driver board, it is being used as the return common for the four motor phase wires.
    Apr 2004
    5950
    That doesn't sound right
    Foil shields are just good for case grounding; they shouldn't be used for current. How many wires are coming out of your steppers? Usually there are 4 or 6. In a 4-wire motor, each phase has a hot and a ground. 6-wire motors are pretty much the same, except you get a choice of running them unipolar or bipolar, depending on whether you hook the separate windings together. Here's a link to a simple explanation of stepper motor wiring:
    http://www.ehow.com/how_4738199_wire-stepper-motor.html
    Andrew Werby
    www.computersculpture.com
    Sep 2009
    9
    Thanks for the tips guys. I wired it up where the frame and cable shielding were connected to DC - and the other end of the cable shielding is floating. Works like a charm, really was a noise issue. Thanks again for the help.
  1. Steppers glitching all axis
    By marman88 in forum Mach Mill
    Last Post: 03-12-2010, 10:51 AM
  2. Anyone In Ontario Selling a Homemade CNC machine
    By Big_Lunn in forum Canadian Club House
    Last Post: 10-27-2008, 03:34 PM
  3. Homemade machine update - a work in progress
    By Chris D in forum Community Club House
    Last Post: 01-14-2008, 07:02 PM
  4. Homemade machine, need some tips
    By originator in forum DIY CNC Router Table Machines
    Last Post: 12-06-2006, 08:01 AM
  5. homemade machine help
    By cadfish in forum Uncategorised MetalWorking Machines
    Last Post: 03-22-2006, 06:54 AM
