588,385 active members*
5,391 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Open Source Controller Boards > YAPSC:10V : The glue between Step/dir and +/-10V servo amp
Page 6 of 13 45678
Results 101 to 120 of 260
  1. #101
    Jul 2008
    84
    i solved my problem.
    noise in encoder.
    thx Iron-Man for guide and support.
    Amir
  2. #102
    Jan 2009
    334
    Quote Originally Posted by manmardam View Post
    noise in encoder.
    Amir
    Great
    I should have mentioned that it is critical that the encoders be shielded.
    I had a similar problem in the early stages of design.
    You can see some of my work here: http://www.cnczone.com/forums/showthread.php?t=40940
    Iron-Man
  3. #103
    Jul 2008
    84
    i used capacitor(104) between A+,B+ and I+ & GND .
    now when i dont have any pulse ,shaft is motionless.
    in addition,i used DC motor(180V) for my spindle.
    i have a question, can i use power stage used in YAPSCV1(DC servo controller) ?
    i need information for do this job.
    Amir
  4. #104
    Jan 2007
    93
    Question
    What signals does PIC output? PWM & direction ,PWM UP & PWM DOWN or Antiphase PWM? Could i controll H-bridge ( ir2110 and ir2184 mosfet drivers ) ?
  5. #105
    Jan 2009
    334
    Amir
    1st, locate the part numbers for the IR’s Power MOSFETs. Go to IR's website and download the spec sheets. This should give you an idea if you can drive the 180v motor.
    2nd, you also need to know how much current it will draw at start up and max power.
    3rd, the power stage can only handle so many amps because of the trace size of the copper in the power stage. I am not sure if max has any information on this. You may have to measure the average trace width in the power stage with a caliper. The circuit board is probably 1 or 2 oz copper. Try this link: http://circuitcalculator.com/wordpress/?p=25/
    I believe that he wrote a manual for the YAPSCV1, check his web site.
    Hope this helps,
    Iron-Man
  6. #106
    Jul 2008
    84
    i need about 10A peak current. i have IRL640(logic gate) and i want test it.
    VDSS=200V & Id=17A and RDS(on)=0.18ohm
    i see YAPSCV1 webpage ,MAX wrote 100A peak but I do not think is achievable
    Amir
  7. #107
    Jan 2009
    334
    Amir
    Check updated info on trace calculations.
    Iron-Man
  8. #108
    Jan 2009
    334
    Quote Originally Posted by visky View Post
    I believe that it is PWM & direction. Go to MAX's site and start there. I have not looked at the specs of the ir2184 & ir2110. Start by comparing these to YAPSCV1, which uses the irl640 I believe.
    Hope this helps,
    Iron-Man
  9. #109
    Oct 2010
    CNC Servo Machine
    :wave:Hello max-mod and all engineers ,
    im in a 5Axis CNC Machine Building prossess, i want use Ac or Brushless dc Motors. i find YAPSC:10V , first tell me can this board drive AC servos ?
    i saw this picture from the : Your page title goes here
    here there are servo motors , servoAmp board , YAPSC:V10 board , Breakout board and at the last , the Computer.
    i have YAPCS:V10 Board ,(i will create this from YAPSC:10V)
    but i dont know what is the servoAmp Board ! is a open Source of this here ?
    im waiting for your companionship in my project.
    thanks
  10. #110
    Hi Everyone
    Has anybody successfully built and has a finished working YAPSC:10v board from using the files on Max-Mod’s website.
    I have tried to contact Max Mod but to no avail.
    Andy
  11. #111
    Oct 2005
    28
    I am also interested in acquiring at least 3 of these boards. I understand that complete boards are available from the seller. Can anyone confirm this? If these are not available, are there any other options?
    Thanks.
    John
  12. #112
    Hi John
    I have had contact with Max, he no longer has the time to continue with this project, however he has told me that all the info needed to make the boards yourself are on the website.
    If I make any headway with this project I will post my progress here.
    Regards
    Andy
  13. #113
    Dec 2004
    1865
    I have 2 of these that I will probably sell.
    They are made by Max and I have the usb programer too.
    If you have any interest PM me.
    Mike
    Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out.
  14. #114
    Oct 2005
    28
    Here I am answering my own queries. After MUCH searching, I have found a card that will take a step/dir signal and output +/- 10v analog. It is the R2040 card from Rutex. Here is a link to the board in question: R2040 - Rutex, USA. I will investigate this option further and report any unusual findings here.
    Regards,
    John
  15. #115
    Apr 2008
    20
    Quote Originally Posted by TOTALLYRC View Post
    Mike
    Hi Mike
    Are you have: YAPSC.10V and: USB ProgKey (what kind - send picture what you selling)?
    If you sell these mail me:
    [email protected]
    Aleksasek
  16. #116
    Dec 2004
    1865
    Hi Aleksasek,
    They are already spoken for. If the deal falls thru I will repost.
  17. #117
    Hi All
    I have had contact with Max and I might beable to get hold of some of the PCB's but these will just be the bare PCB's.
    If anyone is interested can you please let me know, if we can get an order for 20 they could be as low as 2.48 euro $3.40 plus shipping which would make them around $7.50 each.
    Regards
    Andy
  18. #118
    Sep 2010
    where can the yapsc be bought?.......
  19. #119
    Hi DssTvDummy
    I have some bare PCB's on the way,I am going to see how it goes and may offer built and tested boards if Max is ok with it but if you want to roll your own I have some spare boards when they arrive (shipping on the 21st Dec).
    Max no longer has the time to continue with this project but has very kindly let me re order the boards from the same PCB manufacturer.
    Andy
  20. #120
    Sep 2010
    built or roll my own ....either way is fine I just need to get it going.....I have mach3 and a breakout board and analog drives.......Its not making any money sitting there so if you are selling built boards or the PCB I am interested.....just let me know when you get them in.........
Page 6 of 13 45678
  1. Gecko PID step motor servo
    By Mariss Freimanis in forum Gecko Drives
    Last Post: 03-26-2015, 08:54 AM
  2. step motor or servo
    By dcutler35 in forum Uncategorised MetalWorking Machines
    Last Post: 06-09-2012, 06:18 PM
  3. Servo step multiplier
    By JerryFlyGuy in forum Servo Motors / Drives
    Last Post: 05-15-2007, 08:20 PM
  4. Units Per Step For Servo
    By bgolash in forum Mach Software (ArtSoft software)
    Last Post: 02-14-2006, 08:46 PM
  5. Servo and Step motors
    By Dre361224 in forum CNC Machine Related Electronics
    Last Post: 06-09-2005, 02:33 AM
