If you take the terminal cover off, there is generally connection instructions on a label attached.
If not post the present connections and terminal designations as they are often standard.
Keep in mind you may have to increase the fuse and overloads size accordingly, hopefully the wire and contactor size is sufficient for the higher current.
Also check the control transformer to see if the primary can be changed.
Al.
Albert E.
